Go to Post The card system worked. Well. It was used properly and (except for when Paul yellow carded Andy during his "Thank you" speech) wasn't abused. I applaud the referees. Kudos. - Collin Fultz [more]
  #31   Spotlight this post!
Unread 21-03-2016, 07:58
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: pic: New low bar flaps
After two weekends using them on my fields (WPI and UMass Dartmouth) I can say the plastic flaps held up nicely with no rips and only minor scars along the top. Very few zipties popped. Every few matches in my rounds I'd adjust them back to spec -- "evenly spaced" which ends up around a one inch gap between them. There are two holes for two zip ties either side to keep them on, and a ziptie each flap side around the bar to keep them from sliding too much.
There have been a couple of boulders that managed to roll up to the flap and push the flap a little under the bar, but none (that I saw; I can't be everywhere ya know!) ever got thru. If your robot drives thru fast enough one or more flaps swing up and over, or just roll up, which I guess is where the scars on the top come from.
