Go to Post It doesn't matter to me where a FIRST local event is held, I'll be there! - Barry Bonzack [more]
Go Back   Chief Delphi > Competition > District Events
Unread 21-03-2016, 08:12
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: PNW District Championship Projections
The Easter weekend, and just the single event this week might be another factor pushing a lot of teams into the last weekend.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 21-03-2016, 18:57
AaronSchmitz's Avatar
AaronSchmitz AaronSchmitz is offline
Mentor & Volunteer
AKA: Grumpy Mentor
FRC #0949
AaronSchmitz is an unknown quantity at this point
Chairman's still automatically advances, right? So that would bring 2557 (~in), 4125 (~in), 1540 (~in), and 3574 (~bubble) to in along with 4911 and 1983 which are already in.
Unread 21-03-2016, 21:42
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Correct.
Unread 21-03-2016, 22:21
Best Available Data
FRC #1778 (Chill Out!)
How many points does it think the cutoff will be? Has it done a decent job at predicting the points required in previous seasons? I think it was 64 last year & 58 the year before when the dust settled (some declines maybe?). If that benchmark is holding about true, it's probably useful for teams to set their goals & expectations as things move forward.
Thanks for doing this!
Unread 21-03-2016, 23:00
AKA: Eric
Here's what the results looked like:
2015:
2 weeks out: 62
1 week out: 62
Actual: 64
2014:
2 weeks out: 56
1 week out: 55
Actual: 58
It's a small sample size but it does seem to be a little bit biased toward making low estimates.
Unread 21-03-2016, 23:05
AKA: Eric
And I forgot to add: it's already listing what it thinks that the cutoff might be:
Best-case points to make it to district cmp: 37
Worst-case points to make it to district cmp: 97
Best estimate: 52
Unread 23-03-2016, 13:45
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Thanks for doing this again Eric!
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 23-03-2016, 14:04
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Good stuff, Eric!
I'm curious about some of the details of your methodology that I didn't see in your previous posts. Are you taking into account dead points from 3rd plays and un-winnable awards? For example, as far as I can tell, Philomath won't be giving out a Rookie All-Star award, so those 8 points are guaranteed gone from the district.
Unread 23-03-2016, 14:37
AKA: Eric
Originally Posted by Nuttyman54 View Post
Good stuff, Eric!
The methodology is based only on how many total points teams have earned at different events. It takes no other data whatsoever into account.
Here's the basic idea:
-If you've only played one event it estimates an upper bound for points earned at your second as the best that any team has done at an event when one of them was equal to or worse than your first event.
-Similarly, it guesses a lower bound for points based on the worst a team has done that has had an event that's at least as good as your first
After it has ranges for each team, it uses those to create ranges that the point cutoff could be. Then for each team, it compares their range to where the point cutoff could be.
So it doesn't explicitly take into account how many points there are left. However having lots of plays left will change the estimate of where the cuttoff will be by making the bounds wider. So for example, a team might go from listed as "~in" to "in" without a change in either the number of points they've earned or the best guess of where the cutoff will be just because more teams have played events.
So for this year there are two things that are really a big deal as far as trying to get an accurate result:
-There are so many teams that haven't played any event yet. At the moment, teams that haven't played at all are assumed to be exactly average, which obviously wrong. In past years there's only been maybe 1 team that didn't play till the last two weeks, so this didn't really matter.
-The official ranking page's event results are known to be wrong. They haven't fixed they issue about how they account for ties properly. They just give a bonus to the team's overall total rather than correcting the event score. See here: http://www.chiefdelphi.com/forums/sh...hreadid=146151. This throws off the estimates because the system is based on comparing event results.
Unread 27-03-2016, 00:14
AKA: Eric
With just one week left, it's time for an updated set of projections:
Best-case points to make it to district cmp: 41
Worst-case points to make it to district cmp: 92
Best estimate: 54
{'bubble': 44, 'out': 37, '~in': 37, '~out': 27, 'in': 13}
0       in      1983 - Skunk Works Robotics
1       in      2522 - Royal Robotics
2       in      3238 - Cyborg Ferrets
3       in      4061 - SciBorgs
4       in      2046 - Bear Metal
5       in      4911 - CyberKnights
6       in      4488 - Shockwave
7       in      5920 - VIKotics
8       in      3663 - CPR - Cedar Park Robotics
9       in      2147 - CHUCK
10      in      3711 - Iron Mustang
11      in      4205 - ROBOCUBS
12      in      2928 - Viking Robotics
13      ~in     2557 - SOTAbots
14      ~in     3826 - Sequim Robotics Federation "SR...
15      ~in     2930 - Sonic Squirrels
16      ~in     4726 - Robo Dynasty
17      ~in     4980 - Canine Crusaders
18      ~in     2990 - Hotwire
19      ~in     1425 - Error Code Xero
20      ~in     955 - CV Robotics
21      ~in     1318 - Issaquah Robotics Society
22      ~in     4450 - Olympia Robotics Federation
23      ~in     1778 - Chill Out
24      ~in     1595 - The Dragons
25      ~in     753 - High Desert Droids
26      ~in     5450 - St. Helens Robotics and Engine...
27      ~in     4915 - Spartronics
28      ~in     5085 - LakerBots
29      ~in     3223 - Retrobotics
30      ~in     2811 - StormBots
31      ~in     4077 - M*A*S*H
32      ~in     2907 - Lion Robotics
33      ~in     3574 - HIGH TEKERZ
34      ~in     1258 - SeaBot
35      ~in     4125 - Confidential
36      ~in     5942 - Warriors
37      ~in     2149 - CV Bearbots
38      ~in     4089 - Stealth Robotics
39      ~in     5827 - Code Purple
40      ~in     5803 - Apex Robotics
41      ~in     997 - Spartan Robotics
42      ~in     2944 - Titanium Tigers
43      ~in     1510 - Wildcats
44      ~in     2471 - Team Mean Machine
45      ~in     5495 - Aluminati
46      ~in     5588 - Holy Names Academy
47      ~in     949 - Wolverine Robotics
48      bubble  2926 - Robo Sparks
49      ~out    4513 - Circuit Breakers
50      ~out    4495 - Tigers
51      ~out    1294 - Top Gun
52      ~in     1540 - Flaming Chickens
53      ~out    4682 - BraveBots
54      ~in     3786 - Chargers
55      out     6129 - Shadle Park
56      ~out    2923 - Aggies
57      bubble  5468 - Retro-bots
58      bubble  5975 - Beta Blues
59      bubble  5937 - MI-Robotics
60      bubble  2910 - Jack in the Bot
61      ~out    4173 - Bulldogs
62      ~out    4180 - Iron Riders
63      bubble  4131 - Iron Patriots
64      out     3586 - Pride in the Tribe-Caveman Rob...
65      out     2521 - SERT
66      out     847 - PHRED
67      out     2903 - NeoBots
68      out     3712 - RoboCats
69      out     4608 - Duct Tape Warriors
70      bubble  3393 - Horns of Havoc
71      bubble  3024 - My Favorite Team
72      out     4683 - Full-metal Robotics
73      out     3070 - Team Pronto
74      bubble  4469 - R.A.I.D. (Raider Artificial In...
75      out     4120 - Jagwires
76      out     3220 - Mechanics of Mayhem
77      out     4512 - BEARbots
78      out     3812 - Bits & Bots
79      out     2148 - Mechaknights
80      out     568 - Nerds of the North
81      out     488 - Team XBot
82      out     4030 - NullPointerException
83      bubble  3673 - C.Y.B.O.R.G. Seagulls
84      bubble  2374 - Crusader Bots
85      out     492 - Titan Robotics Club
86      bubble  4692 - Metal Mallards
87      bubble  2411 - Rebel @lliance
88      out     2976 - Spartabots
89      bubble  3674 - 4-H Clover Bots
90      bubble  2412 - Robototes
91      bubble  4057 - STEAMPUNK - Klamath Basin Robo...
92      bubble  2733 - Pigmice
93      bubble  3221 - KM Royals
94      out     6076 - Mustangs
95      out     5198 - Knight Tech
96      bubble  5970 - BeaverTronics
97      bubble  4309 - 4-H Botsmiths
98      out     2605 - Sehome Seamonsters
99      bubble  4051 - Sabin-Sharks
100     bubble  4043 - NerdHerd
101     out     4082 - Ranching Robots
102     bubble  360 - The Revolution
103     bubble  4662 - Byte Sized Robotics
104     bubble  5941 - SPQL
105     bubble  3787 - Wild Robotocats
106     bubble  5956 - Falcons
107     bubble  1432 - Metal Beavers
108     bubble  948 - NRG (Newport Robotics Group)
109     out     3693 - GearHead Pirates
110     bubble  1359 - Scalawags
111     bubble  3588 - the Talon
112     bubble  2906 - Sentinel Prime Robotics
113     bubble  4132 - Scotbots
114     out     3268 - Vahallabots
115     bubble  4110 - DEEP SPACE NINERS
116     out     3789 - On Track Robotics
117     bubble  2635 - Lake Monsters
118     bubble  2002 - Tualatin Robotics
119     bubble  3684 - Electric Eagles
120     bubble  2550 - Skynet
121     out     3681 - Robo-Raiders
122     out     1899 - Saints Robotics
123     bubble  4681 - Murphy's law
124     bubble  5683 - RAVE
125     out     3192 - Tiger Bytes
126     out     4918 - The Roboctopi
127     out     4104 - Blackhawks
128     ~out    5977 - Rosemary Anderson H S/POIC
129     out     4127 - LoggerBots
130     bubble  3781 - Cardinal 4-H Robotics
131     out     3575 - OK Aggies
132     ~out    5939 - Lakes Lancers
133     bubble  4654 - Mountaineers
134     out     957 - SWARM
135     bubble  2927 - Pi Rho Techs
136     bubble  3219 - TREAD
137     ~out    4060 - S.W.A.G.
138     ~out    2980 - The Whidbey Island Wild Cats
139     ~out    4461 - Ramen
140     ~out    3237 - Bionic Braves
141     out     3876 - Mabton LugNutz
142     out     5111 - SaxonBots
143     ~out    5748 - Octo π Rates
144     ~out    3049 - BremerTron
145     ~out    2929 - JAGBOTS
146     ~out    3218 - Panther Robotics
147     out     2660 - Pengbots
148     ~out    3636 - Generals
149     ~out    1571 - CALibrate Robotics
150     ~out    5295 - Aldernating Current
151     ~out    2915 - Riverdale Robotics/Pandamonium
152     ~out    2555 - RoboRams
153     ~out    2942 - Panda ER
154     ~out    4579 - RoboEagles
155     ~out    3131 - Gladiators
156     ~out    3576 - Clover Park High School Warrio...
157     ~out    3831 - Da Bears
Note that the official district ranking system still contains manual point adjustments which are not reflected in this calculation.
Unread 27-03-2016, 13:29
InFlight's Avatar
AKA: Jim
Too hard even guess now, we will have to wait for Oregon City and Auburn to finish. There's a lot of traditionally strong teams that need a good performance in week 5 to return to the district championships.
Team 1510 Wildcats won the Philomath Chairman Award and are officially "in".
Unread 27-03-2016, 13:40
Best Available Data
I agree that some traditionally strong teams have had an off year, but Eric's method of estimating which teams will advance has a pretty solid track record (especially with only 1 week & 2 events left).
Look at his postmortems from 2015 & 2014.
Unread 27-03-2016, 16:01
I wouldn't worry. With 69 points, 3574 is a lock for DCMP. It would have been enough last year too, even with one more event in the district.
Founding Member
Unread 27-03-2016, 18:15
InFlight's Avatar
AKA: Jim
With many teams having had three or four weeks off between events; there has been lots of time to improve mechanisms and perfect code. With this year's odd schedule; we might see some real performance improvements from first weeks scores/performance from the strong veteran teams.
Might be a year that modeling based on early results will have weaker correlation.
Unread 03-04-2016, 22:03
Maria S Maria S is offline
FRC #2944 (Titanium Tigers)
Maria S is an unknown quantity at this point
Final rankings are up!
