Go to Post "So Ken Patton, Paul Copioli, and John V-Neun walk into a bar..." - JVN [more]
Unread 21-03-2016, 08:38
Re: Help Needed!!! No Robot Comm, No Code.
Originally Posted by D.gimon View Post
However, Driver Station icon has a blue and yellow shield superimposed on it in bottom right hand corner which I haven't seen before.
I think that's Windows telling you that the Driver Station program will need to be run with elevated privileges in order to function properly. Try running it as Administrator and see if the communication works.
The best option is probably to log on with an administrator account instead of a limited user, turn off the antivirus and firewall, and then be very careful about what you click on if you ever connect it to the Internet.
