Go to Post Basically, it just doesn't matter. - Mark Pettit [more]
Unread 20-03-2016, 19:51
aphelps231's Avatar
aphelps231 aphelps231 is offline
Andrew Phelps
FRC #1318 (Issaquah Robotics Society)
aphelps231 has a spectacular aura aboutaphelps231 has a spectacular aura about
775 pro likely to pop breakers?
How likely is a 775 pro from Vex to pop a 40A breaker? Usually we don't use them because we've heard they pop breakers easily when they are stalled.
It would be used on an intake in place of a BAG motor that didn't have enough power. Or maybe there's another motor that fits on a versaplanetary gearbox that's better than a BAG motor and isn't a 775 pro?
team1318.org
2016: Flight Director, Alliance/Match Strategy
2015: Mechanical Lead
2013-2014: Fabrication
2016: 2x district finalists, Quality, DCMP Entrepreneurship Awards
2015: 3x district winners, Innovation in Control, Creativity, Team Spirit awards
2014: Galileo Division finalists, PNW District Championship winners, 1x district winners, District Chairman's, Innovation in Control, Entrpreneurship awards
2013: Entrepreneurship award
Unread 20-03-2016, 19:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: 775 pro likely to pop breakers?
It might be easier to make a recommendation if we could see what it is you are trying to power with the motor, and if you let us know what gear reduction you are using, and roughly what the load is on it.
If you set things up right, the motor won't ever be in a situation where it will stall....
Unread 20-03-2016, 19:55
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Just curious, what is your reduction on your BAG motor? It's kind of curious to me that it would have trouble with the ball.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 21-03-2016, 09:50
aphelps231's Avatar
Andrew Phelps
It stalls out when the ball is under the mecanum wheels on our intake, because it takes a decent amount of torque to move it to the center when it's being pushed against the bumper by the mecanums.
team1318.org
Unread 21-03-2016, 10:01
Michael 4499 Michael 4499 is offline
FRC #4499 (The Highlanders)
Michael 4499 is on a distinguished road
We use a bag motor geared down 25:1 on our intake with mecanums to funnel it to the center of the robot with no problems. It is possible to still use a bag motor for this.
2016 Galileo & Carson - Gracious Professionalism
2016 Colorado - Chairman's award, Finalists
2016 Arizona North - Engineering Inspiration
Unread 21-03-2016, 10:02
Chris is me's Avatar
AKA: Pinecone
This depends on a variety of factors but the short answer is if the motor is stalled under 100% power for an extended period, it will likely trip the breaker and will eventually puff up in smoke.
Whether or not this stall condition is likely to happen depends on a few things - gear ratio, loading, etc - and what stalls a BAG motor at a certain reduction may or may not stall a 775. A 775 geared to a lower reduction that matches the speed of the BAG motor will have more torque due to the higher power of the motor, so it's possible you won't have the stalling problem you do now.
But if you think your intake will still stall even with a different motor / ratio, the 775pro is not a motor designed to be stalled at full power for extended periods. But how does your intake work at all if it is consistently stalling?
Unread 21-03-2016, 10:10
MrForbes's Avatar
AKA: Jim
...somewhere...there must exist a picture of this robot?
Unread 21-03-2016, 10:13
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Stall current for a 775PRO from Vex is 134 Amps (according to Vex)
Trip time for a 40 amp snap action breaker @ 3x load is 0.5 to 1.1 seconds. (according to AndyMark)
Whether you stall the 775PRO or not depends on your gear ratio, not the motor itself. Stalling a 775PRO is very bad for the motor as it has an integrated cooling fan on the shaft so as you stall the motor (highest heat output) you also stop the cooling fan. This will eventually let out the magic smoke.
___________________
- Tennyson, Ulysses
One thing that should enter into this discussion is the design of the motor. The 775, like the Fisher Price motor, requires cooling air to flow through the motor. The integral fan requires a minimum RPM and the vents in the end of the motor need to be open for air to flow. Use carefully with those items in mind.
Unread 21-03-2016, 10:16
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
It looks like your options are to either intake slower or add a second motor. The 775 pro would be the most likely replacement. There's a lot of theoretical gear ratio and motor curve stuff involved, but assuming you need the stall torque of a BAG to intake a ball and you're geared for the same speed, a 775pro would be pulling 56 amps, vs the BAG stalling at 53A. Admittedly, the pro would still be turning at about 60% free speed at that point. But if you need even more torque than that to intake for a second or two, then yes, you're going to start pushing the limits of breakers and speed controllers. It's possible that the higher stall torque will let you power a ball through the mecanums faster and keep you from stalling and blowing things, but I wouldn't want to bet the farm on it.
Gearing slower or adding a second BAG would get you more torque per amp per motor, and thus reduce your chance of blowing things. Two 775pros would probably be even better.
Unread 21-03-2016, 10:22
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
This is great advice.
That said, we love the 775pro for it's power-to-weight ratio. We use 8 775pro's and 4 CIM's on our 2016 robot, haven't tripped a breaker yet!
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 21-03-2016, 10:45
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
For our intake we are using a MiniCIM geared at 4:1 on a VersaPlanatary. Like others have said, the 775pro is an air cooled motor, so it needs ample room for heat dissipation and air intake.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 21-03-2016, 10:51
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
We used 8 775Pros on our drive train, 1 on the intake, and 2 on our scaling mechanism. The only time we popped a breaker was when we had only 1 on the scaler.
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 21-03-2016, 11:30
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Keep in mind the even the CIMs have a pretty short duty cycle even when running at rated speed. Run any of the FRC motors at full voltage and stall and you will rapidly overheat and smoke them. The CIMs and their smaller relatives do better because of their greater thermal mass & reliance on conduction rather than convection for heat transfer. The motors with stall currents > 40amp will eventually cause the breaker to chatter or the speed controller to pull back the voltage to the motor (Assuming the speed controller has that function built in).
So if you are using any brushed dc motor for positioning you should keep this in mind. If it takes more than 20%-40% percent of the full voltage stall current to hold the position, you are going to rapidly overheat the motor. For motors than use fan cooling consider ducting one of the KOP fans to help with cooling
Unread 21-03-2016, 11:34
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by MaGiC_PiKaChU View Post
We used 8 775Pros on our drive train, <snip>
Say on sir. Had this motor been out earlier in the fall and had weight been an issue, I would have pushed very hard for a (8) 775Pros over (4) CIMs but without time to really suss this out, I was just too scared to advocate.
What are your ratio(s) (motor to wheel please), tires (size and grippiness), chassis configuration (# of wheels, any lowered if so how much, distances between wheels side to side and fore/aft)...
In general, open wide your kimono Mr. PiKaChU, open wide...
Dr. Joe J.
Team #88, TJ2
