Go to Post I guess we're going amish this year. - Jon Anderson [more]
Unread 21-03-2016, 13:25
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: COMM lost way to many times
Originally Posted by mwtidd View Post
The problem is solved with hot glue.
hot glue where?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 21-03-2016, 13:28
Bruceb's Avatar
Originally Posted by Conor Ryan View Post
This sounds like a power quality issue. Bad wires, bad crimps, bad connections, bad barrels all can contribute to this.
I would replace all of the wires from the batter to the radio, especially the black wires that go directly into the radio. Then I would reprogram your firmware on the radio in particular. Inspect your fuses, many people don't notice when they are bad. Drive the robot around at home, drive over bumps see if you can replicate these issues. Make sure all of your wires are anchored down appropriately and nothing can shake loose. Make a good effort to replicate the driving conditions on the field, move around fast and crash frequently.
With how difficult the field is on robots this year, i'm not surprised that we are seeing a rise in power quality related issues on the communications.
ya but the robot is in the bag
Unread 21-03-2016, 13:29
Bruceb's Avatar
Originally Posted by protoserge View Post
What is the battery voltage showing on the logs? How old are your batteries?
[Bad advice retracted].
Try driving the robot in a stall condition by putting it against a wall and driving forward. See if your radio restarts.
we have all kinds of batteries but we lost comms some times when we were just going under the low bar. No big current draws, no big bumps.
Unread 21-03-2016, 13:34
bdaroz's Avatar
bdaroz bdaroz is online now
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
We had some issues with our radio and/or FMS at the Tech Valley Regional this weekend.
One of them was on us (tug test failed on our radio power connector), the other was indeterminate. (CSA/FTA was blaming robot power, as a whole, but we have video showing no power loss on the RoboRio.)
Regardless of what the problem is, even as a rookie team, the instrumentation provided by the RoboRIO/PDU/FMS/DS completely fails during problem events.
During the aftermath of our issues, we attempted to use the DS logs to trace voltage, power draw, comms, and log messages from the RoboRIO. The problem is, you can make "guesses" about your voltage state in the fraction of a second leading up to the event, but once it happens, you're blind.
We're already redoing our robot code library for next year to address some of these shortcomings. We'll be logging voltage and PDU stats, as well as bridge/radio and FMS connectivity via ethernet directly on the RoboRIO. In addition we'll be using a cached-logger, such that if DS communication is lost we can back-fill in our logs.
We are attempting to address the issue of the complete lack of FMS logging, and the logging dropout during any communication loss event. We're also pushing the logging closer to the source of the data. Our goal is to be able to document the voltages, RoboRIO, PDU, and Radio/FMS/DS status in an effort to diagnose issues.
Unread 21-03-2016, 13:49
philso philso is offline
FRC #2587
Do a pull test on all wiring connections. That means where a wire goes into a Weidmuller or Wago connector, where a wire goes into a crimp lug, where a wire goes into an Anderson connector and where the wires go into the plug for the RoboRio power. If wire slips out, re-do the connection.
Check all screw/lug connections such as the battery cables on the battery and on your main breaker. The wire and lug should not be able to rotate relative to the battery or breaker. Tighten the screws if they move.
Use a flashlight and examine closely where the wires go into the small Weidmuller connectors (i.e. RoboRio power on your PDP). Look for stray strands on any wire that is not in the connector. These stray strands can touch adjacent wires which is always the opposite polarity on the PDP, VRM and PCM. If necessary, cut off the "crinkly" stripped ends, strip to the length shown in the Users Manual for the PDP, VRM and PCM, twist the exposed strands so they lay neatly together then re-insert the wire in the Wiedmuller connector carefully and ensuring that ALL the strands go in.
Unread 21-03-2016, 13:52
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
What in the video establishes that there was no power loss on the RoboRIO? If you're just looking at the Robot Signal Light, it's possible that your RoboRIO browned out due to power loss, but didn't completely shut off.
Unread 21-03-2016, 14:25
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Originally Posted by Bruceb View Post
hot glue where?
We solder and heat shrink where we can, and hot glue everywhere else. So the connections to the Voltage Regulator are all hot glued. We were seeing all sorts of radio drops out just as you've described on both our comp and practice bots. Since hot gluing the radio wires into the voltage regulator we haven't lost comms. (~19 matches).
We use hot glue on nearly every connection, including our encoder cables, limit switches, arduino plugs, etc.
If you want something less permanent electrical tape tends to work well enough, but I haven't seen anything better than hot glue this year.
Unread 21-03-2016, 14:28
ATannahill ATannahill is online now
AKA: Alex Tannahill
So everyone knows, the DS logs are able to tell you if the roboRIO rebooted.
When a connection is established between the roboRIO and the DS the roboRIO will send a message saying how many seconds have passed since it last booted up, the DS then stores this information in the log. Look at the messages when communication is reestablished to find this information.
Unread 21-03-2016, 15:18
Originally Posted by Thad House View Post
I would LOVE to see FIRST legalize opening up the Radio and soldering a power cable directly to the PCB pins. Not having a solid, locking connector is the biggest issue with the radio, and if teams could solder to create their own locking connector, maybe with a powerpole that would be great.
Why is everyone missing the obvious solution? Use passive Power Over Ethernet (POE) on the port that supports it. The Ethernet connector snaps firmly into place. I've never seen one come loose due to bounces or vibration this year.
On the other hand, more than half the robots I checked had loose terminals either on the battery or the main circuit breaker. All of the "lost communication" events I followed up on at both of the events I worked at were associated with a faulty power connection. All.
(I'm counting only ones where there was actually a loss of communication, not the few the drivers called "lost comm" but where the problem was that robot code crashed or a joystick came disconnected or the Driver Station was being interfered with by a software update process.)
Unread 21-03-2016, 15:46
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
chadr03 has a spectacular aura aboutchadr03 has a spectacular aura aboutchadr03 has a spectacular aura about
I'm not familiar enough with PoE to be comfortable without some details. I sure don't want to fry a radio. With a quick search I haven't found out the best way to wire a PoE for this this radio. I assume you can use the 12 v port on the VRM into a spliced ethernet cable but what pins are used and which port does it go into in the router. I apologize if this has already been discussed. I didn't see it in my searching, but might have been looking for the wrong things.
Unread 21-03-2016, 16:01
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
FIRST should consider allowing the use of a small secondary battery to power the radio should it lose connection with the VRM/PDP. The battery would be used exclusively for the radio and prevent any reboots due to power loss or brownouts elsewhere on the bot.
Consider that batteries and the PDP are generally well-hidden on the bot (the battery to lower CG and the PDP to shorten total wire lengths. However the radio needs good clearance from metal and motors to ensure a solid RF connection, leading to longer wires and generally less secure mounting (subject to more vibrations potentially). This all introduces risk of wire/connector failure. Allowing a small battery placed alongside the radio as a parallel backup would be beneficial.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 21-03-2016, 16:37
All the information I needed I found through the OpenMesh web site and a simple search for "passive POE". I summarized it here.
Unread 21-03-2016, 16:44
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
hot glue where?
Hot glue at the connection between the power plug and the radio.
I was the mentor from 379 that was trying to help. At the time we probably couldn't wait for a hot glue gun to heat up We reset all wires at the VRM. Checked other connections, inspected contacts, and zip tied the battery connection. Not knowing the robot, it was hard to inspect.
I do feel that it's something dealing with an electrical connection. Try replacing the Anderson battery/PDB connection, wire and all, from the robot. I wish we could have figured it out, you guys have a great design, good luck this season.
Unread 21-03-2016, 16:54
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Which port on the radio supports POE?
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 21-03-2016, 16:59
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
I highly recommend against hot gluing the plug into the radio (and I also advocate against hot gluing or taping ethernet cables and power cables pretty much anywhere). It makes replacing those wires later more difficult.
The radio's plug is particularly problematic with hot glue. You can no longer easily detach the radio from your robot to program it at events, and swapping out radios should yours need to be replaced for any reason suddenly becomes much more difficult.
Furthermore, the issues I have seen are generally not that this plug comes loose. The problems are generally that the wires going into the Weidmuller connections on the VRM have too much copper showing and are shorting out, or that there are loose wires elsewhere in the chain.
I had a team that had mummified their Ethernet ports on both the radio and roborRIO along with the USB cables going into the roboRIO and the power plug on the radio with electrical tape drop out during a match. Seriously, there was a large mound of the stuff over everything. They asked me if I thought they should add more electrical tape since they were still dropping out. At that point I demonstrated that the wires going to their radio were just falling out of the VRM with very little effort on my part.
Understand the problem before trying to apply bandaids. You might not even be putting the bandaids in the right spot.
Team 2052- Knightkrawler
Mentor and volunteer
