Go to Post I then asked if I could use a flux capacitor for power, but that didn't go over too well, either (they did say I could use it for decorative purposes, though). - Kevin Watson [more]
  #36   Spotlight this post!
Unread 21-03-2016, 14:14
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Check your Anderson battery connectors
We've had a few issues with the contacts separating slightly woke the connector was mated. One of these was supposedly from the contacts having come off the retaining clips (not sure how, but I've seen this before on our battery charger ). On the other, if I rotated the wire, then the contact also rotated in the connector. We've instituted an inspection since they on order to catch these and I've had some spare cables made up on case we see more. I think we're starting to see aging issues with the wiring. These connectors are mated and unmated frequently and may be wearing out the housings and contacts.
