#61
Re: Banging the driver station
Today in semi-finals a robot on the alliance we faced was known to smash into the driver station wall every match in autonomous. To prepare for that we put our logitech controllers behind our already-velcroed laptop, however when they hit our station they actually managed to bang the lid of our laptop down such that we didn't have control of the robot for about the first 5-10 seconds of the match. After this incident, the head ref told us that in the next match we could hold our driver station (two controllers and a laptop) in place if we saw that they were about to hit us, as long as we didn't give the driver station any input. We ended up not having to do this because of the defenses we selected, but I think this was a great way to deal with the situation on the ref's part.
#63
There was an instance where this happened at The Chestnut Hill district event where a robot rammed into the drivers station and dislodged our controllers and our laptop fell on the ground. Although this was not a repeated action from this team I can see where this would appear as very aggravating and why you would expect a penalty from such behavior.
#65
I was cringing until I saw he really wasn't touching it. (Not for his foot, mind you; I didn't want to quickly replace the driver wall )By the way, there were a couple of times robots would push the driver wall back. Which isn't easy, considering the weight and velcro. One time it was four inches! Viva la AndyMark fields! |
#66
Something about a pair of Jordan's will get your feet off the ground.
#67
It's not the shoes. Karthik can fly because he is really The Great Gazoo.
#68
Plus he starts from the Defenses to get a running start... but I'm probably giving away trade secrets.
#69
I would be thinking the same way as you if one of the robots hadn't smashed into the wall so hard in autonomous as to bend the drivers wall inwards. No foul was given, but despite the velcro on our drivers station, pushed it almost to the point of falling off.
#70
[tongue in cheek]If a team sits there while a robot drives into them full speed would be at least a little bit the referees fault for letting them on the field during a match.[/tongue in cheek] As a side note, at the Georgia District Columbus event, teams where hitting the defenses hard enough to damage them. All where warned that after a warning on the field, they would be penalized. Last edited by FrankJ : 21-03-2016 at 15:58. Reason: added a bit |
#71
IMO if your driver station falls off its your own fault. I don't want to sound mean, but FIRST provides Velcro on the DS shelf for a reason. At CIR over last weekend we saw a couple of teams lose their DSs to auto slams. In the end one of them ignored the Velcro and went straight to a C-clamp.
Long story short use the Velcro that's provided, and your DS should be fine. If your controllers are falling off, Velcro them down too. |
#72
If the indicator light and team number flew off because a robot ran into the wall, they were not properly installed.
#74
And on top of that you can't give a team a yellow or red card because the field is setup wrong. That is grounds for a field fault and redo.
#75
We had our DS knocked off at CIR this weekend as well, despite having velcro on it to secure it, as we have had on that OI case for the last 4 years. This did absolutely nothing in our case. I have never seen a robot hit the wall as fast or as hard in my 7 years in FRC. And when you are watching your own robot at the other end of the field to see if its auto worked, you aren't necessarily watching what's coming at the wall in front of you. We had maybe half a second to react before the DS was just above the floor, laptop now closed, and hanging by cables. We lost all manipulator controls for that match, and the USB port they were plugged in to did not work properly again. It seems we also lost the other USB port in use at the time, which later was intermittent and unreliable, and at this point, seems to be the reason we lost drive control in the middle of our last two semifinals. We are buying a new DS laptop today as a result. Did we use velcro? Yes. Could we have stepped forward to catch it? With Spiderman reflexes, yes. Were the refs within the rules to not replay the match? Yes. Did I have a very unhappy drive team? Yes. Did the team adjust their auto? Yes. Was it our fault? No, I don't think so. Last edited by SteveGarward : 21-03-2016 at 16:02. |
