Go to Post I want to understand the physics. - Molten [more]
Unread 21-03-2016, 16:15
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Banging the driver station
Originally Posted by IronicDeadBird View Post
And on top of that you can't give a team a yellow or red card because the field is setup wrong. That is grounds for a field fault and redo.
Can you tell me that the team sign and lights being moved caused a difference in the outcome of the match? T20 requires the Head Ref to determine if a replay is necessary based on a potential change in outcome. It is possible they were in a position to interfere with the view of the drivers, but if they were simply hanging from their wires (which I would expect to happen if the mechanical attachments that Wetzel referenced somehow failed) I doubt it would have a significant impact.
