Go to Post shhhh...our robot is in a bag now, it won't hurt anyone till the milwaukee wisconsin regional. hopefully it won't be fiesty. don't wake it. - Toatekua [more]
Unread 21-03-2016, 18:52
DanG100 DanG100 is offline
DanG!
FRC #2367
DanG100 is an unknown quantity at this point
NetworkTables compile issues
I'm trying to use network tables in C++ on windows, using Visual Studio.
After building with gradle and including the proper directories, I get several errors.
Error 5 error C4996: 'ITable::GetNumber': Raises an exception if key not found; use GetNumber(StringRef key, double defaultValue) instead	C:\ntcore\include\networktables\NetworkTable.h 477	1 GoalDetection
I get similar error for GetString and GetBoolean
Unread 21-03-2016, 18:58
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: NetworkTables compile issues
All you have to do is use the same function with different parameters. Instead of:
table->GetNumber("x");
do this instead
table->GetNumber("x", 0.0);
This just sets a default value for that value in the table in case the robot is not connected to the driver station yet. If it didn't it would throw an exception, like it says in the error.
Unread 21-03-2016, 19:10
DanG!
FRC #2367
The error I'm getting is in NetworkTable.h, I got the error as soon as included the file.
Unread 21-03-2016, 20:58
jreneew2's Avatar
AKA: Drew Williams
Have you looked at this link:
https://wpilib.screenstepslive.com/s...client-pc-side
It is for java, but I'm sure you could easily translate it.
