Go to Post It's not about a team having lots of money to spend to travel the world to share FIRST but how the team draws the world into their FIRST experience. - Steve W [more]
Unread 21-03-2016, 20:25
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Wire Size
The compressor voltage is separate from the solenoid voltage - the compressor will always run at 12V, regardless of the position of the jumper. So don't worry about that!
As for the wires... the PCM should be sitting behind a 20A fuse or breaker (per R44 and R48), so 18 gauge wire is appropriate.
2016: Lake Superior WFFA
Unread 21-03-2016, 20:28
nlt5 nlt5 is offline
FRC #5676
nlt5 is an unknown quantity at this point
Re: Wire Size
Thank you for the quick response. We are going to have our compressor off the robot so we need to have quick connects to plug the compressor into the PCM. The PCM is behind a 20 amp fuse but can I connect 18 gauge wire to 16 gauge wire?
