Go to Post My nagging fear is that I'm a programming dinosaur, stuck in a procedural tar pit and doomed to extinction as the dataflow mammals take over. - Alan Anderson [more]
Unread 21-03-2016, 20:21
nlt5 nlt5 is offline
FRC #5676
nlt5 is an unknown quantity at this point
Wire Size
The wire's on our compressor are 16 gauge, I believe, which are too big to fit into the PCM. It does not seem correct to use 18 gauge from the PCM and connect those to the 16 gauge compressor wire. Is this okay to do and if not what can we do to properly connect our compressor to the PCM. Second question...We need to run on the 24 volt side to get our double solenoids to work but our compressor is a 12 volt. Can we do this? or will we destroy our compressor running the PCM on the 24 volt side?
Thank you for the support
Unread 21-03-2016, 20:25
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Wire Size
The compressor voltage is separate from the solenoid voltage - the compressor will always run at 12V, regardless of the position of the jumper. So don't worry about that!
As for the wires... the PCM should be sitting behind a 20A fuse or breaker (per R44 and R48), so 18 gauge wire is appropriate.
2016: Lake Superior WFFA
Unread 21-03-2016, 20:28
FRC #5676
Re: Wire Size
Thank you for the quick response. We are going to have our compressor off the robot so we need to have quick connects to plug the compressor into the PCM. The PCM is behind a 20 amp fuse but can I connect 18 gauge wire to 16 gauge wire?
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: Wire Size
16AWG wires fit perfectly fine if correctly stripped in the PCM. I believe it would be against the rules and possibly dangerous to use 18AWG wires to connect the compressor.
I would personally check this out https://wpilib.screenstepslive.com/s...ing-pneumatics
Unread 21-03-2016, 20:31
Re: Wire Size
This is incorrect.
R49 specifically lists "Compressor outputs from the PCM" as being 18 gauge as the minimum wire size. The same for the sires between the PCM and the PDP.
Unread 21-03-2016, 20:53
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
For a quick connect, head down to local hobby shop and get connectors for rc car batteries. Very durable and easy to integrate. I would not recommend hooking and unhooking to the pcm.
Unread 21-03-2016, 21:07
Sperkowsky's Avatar
Originally Posted by Jon Stratis View Post
This is incorrect.
Alright so, it is not illegal but I am still wondering why the op is having issues using 16awg wire with the PCM as it is designed specifically for 16awg.
Unread 21-03-2016, 21:40
philso philso is offline
FRC #2587
Re: Wire Size
If you are having trouble fitting the the 16 AWG wire into the PCM, are the wire strands all "crinkly" or frayed? If so, try cutting off the part you have stripped now and re-strip it to the proper length (see the PCM Users Manual). Twist the stripped part of the wire with your finger tips so that all the strands lay together nicely in a tight and round bundle. Use a small screwdriver to push the button on the Weidmuller connector as far down as it will go. Don't push too hard or it will never come up again and you will have to send your PCM to CTRE for repair. Insert the wire into the hole until no more un-insulated wire is showing. the 16 AWG will be a tight fit so be patient and don't rush and fray the wire on the sides of the hole. All strands must be in the same hole with none sticking out to the side where it can short on adjacent wires. Release the button. One needs a steady hand and patience to do this. A flashlight can help too.
