Go to Post According to my father the hint should be released sometime next week, but he's never been the most trustworthy source of info.... - Lil' Lavery [more]
Unread 22-03-2016, 05:51
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Electrical / Software test bed
http://playingwithfusion.com/productview.php?pdid=65
If you are a labview team.
We also built the simbotics Kit bot on Steroids with the 4 slot crio that is still supported in labview, with the old control system.
We also have pneumatic test board, that kept getting ripped apart whenever we needed parts. Last offseason, we rebuilt it once more, this time with non-legal FRC parts. Guess what, it is still together today.
The sooner we get behind schedule, the more time we have to catch up.
Unread 22-03-2016, 07:54
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Are you coming to Marysville this weekend? Could you bring one of these, would like to check it out....
Unread 22-03-2016, 08:20
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Window motors are great for test beds, because you can easily see what direction they are turning without adding wheels.
We try to use the same type of controller/relay as we have on the robot to reduce/eliminate the changes needed between the testbed and the actual robot.
We have also included feedback on some of our test beds (often manually activated limit switches). We usually start with about twice as big a board as it looks like we'll need, and end up filling it by the end of the season.
Unread 22-03-2016, 09:07
BrianAtlanta's Avatar
BrianAtlanta BrianAtlanta is offline
FRC #1261
BrianAtlanta has a spectacular aura aboutBrianAtlanta has a spectacular aura about
One issue with a programming bot is keeping it close to the competition bot, if you want to develop code while the competition bot is being built. Depending on team resources (students and money) can be a challenge.
I've been thinking this season about how start developing competition code sooner in the season. One idea I've been thinking about was prototyping a electrical harness. Here's my current thinking, using this years game. Please, suggestions are welcome.
1. After strategy, build breaks up in to 4 groups for prototyping (drive train, shooter, intake and lift)
2. Once a design is selected from each group, build starts designing and building. But at this point, electrical knows the components needed. They might change with further build enhancements, but you have a starting point.
3. As the build team works, a person or two take the required components and create a prototype harness on polycarb, rio, radio, pdp, and which ever components needed of the the subsystem.
4. Programmers can program, granted driving forward 5ft is hard to test without a bot. But you could tell that the bot motor started spinning and stopped. Once you get on the bot, then you tune the values.
5. Once build is ready for wiring, the test harness is used on the bot.
Brian
Unread 22-03-2016, 09:59
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
I use a fairly simple Test-Bed for testing OpenRIO code during the Offseason. Here's a few suggestions:
- Battery: Don't do this. Use a 12V wallwart if you're powering just a RIO / Radio, it'll save you so much time, especially if you're testing code for long periods of time. If you're using actual motors, then the battery is a good idea. Just be prepared to charge it.
- Radio: Honestly don't even bother. Just link your computer to the RIO using USB, or your RIO to a Local Network (you could use an old D-Link router for this, just turn off the wireless). Waiting for windows to find the wireless network each time you reboot the testbed isn't worth it, and it also means if you're on the Local Network you'll have Internet Connectivity without switching networks if you need to troubleshoot something or procrastina-- help the community on Chief Delphi
- Motors: Use small, low-power motors that aren't very fast. If they aren't very fast, it'll be easy to tell which way they are turning and how fast (as a rough percentage). Low-power means you don't have to swap out your battery very often.
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 22-03-2016, 10:12
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Depending on what exactly you want to do, you could definitely power it all using a 12 volt wall wart (use the highest current output you can find) or a 12 volt bench power supply (5-10A or more).
If you don't need real motors and motor controllers, you can plug in servos to stand in for motors. Continuous rotation servos would give you a good visual indicator of movement. If you're not using motors or other high current draw devices, you can probably dispense with the PDP entirely.
How many RoboRios do most teams have? If we had the resources I'd want at least three: one set up in a testbed configuration like this, another one mounted in a full drive platform (either purpose built, or reusing a robot from previous years) for autonomous testing, and then the competition robot.
Unread 22-03-2016, 10:42
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
I'm fairly lazy, so I don't bother with a testbed... I just use a low-fidelity robot simulator (pyfrc), and we can simulate most robot actions without further modifications.
Unread 22-03-2016, 11:05
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
If you are talking about the linked robot, I do not have one... Someone on CD pointed it out and I had a dad on the team talk about buying one.
If you are talking about the pneumatic test board, I can toss it in.
