Go to Post Afterall, there's a thread for everything and everything in it's thread. - Molten [more]
Unread 22-03-2016, 07:09
MAXOFLIFE's Avatar
MAXOFLIFE MAXOFLIFE is offline
Bolton Bear Bots Member
AKA: Maxwell Huffman
FRC #3666 (Bolton Bear Bots)
MAXOFLIFE is an unknown quantity at this point
What types of metal do you use for your robot in general?
This year we constructed most of our robot using 1"x1" aluminum tubing. It worked, but we had numerous problems: warping from over tightened bolts, extra holes needed to help guide and tighten bolts, etc. I know every year can be different, but what types of metals (and in what shapes and forms) do you mainly use and for what reason? We know the basics: aluminum being lightweight, steel being strong; heavy; and prone to rusting, etc.
Thank you for taking time to help!
Unread 22-03-2016, 07:19
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: What types of metal do you use for your robot in general?
We used a lot of 2x1 and 1x1 Versaframe. We also made use of some aluminum flat stock, steel flat stock, and pieces of old KOP chassis....
We used the Versaframe mostly because of the pre drilled holes and how easy it is to buy. The 1x1 was really just used for extra support and for mounting bumpers. The 2x1 formed the majority of the shooter structure.
The aluminum flat stock was bent and used to build the platform the boulder rests on. We would have probably used steel if we had the means to bend it.
The steel flat stock was used to mount a cylinder.
And, the pieces of old KOP chassis were used as a climber hook, battery mounts, and a little extra support for the underbelly.
Unread 22-03-2016, 07:34
Cam_Team 2619's Avatar
Cam_Team 2619 Cam_Team 2619 is offline
Director/King of The Mill
FRC #2619 (The Charge)
Cam_Team 2619 is an unknown quantity at this point
Our team uses a lot of .75" x .75" aluminum tubing. Never had a problem with it.
2014 - King of The Mill
2015 - Mechanical Co-Lead/Human Player Backup
2016 - Mechanical Lead
2017 - Director
Unread 22-03-2016, 07:56
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by MAXOFLIFE View Post
... warping from over tightened bolts, ...
If your team has access to a wood shop (table saw, planer, joiner, etc.) it is easy to make tight fitting wooden plugs, one to three inches long, to go inside rectangular or square aluminum tubes. This makes it easier to join tubes, using gussets, through-bolts, pivot bushings, etc., without crushing them when you tighten the fasteners.
Richard Wallace
since 2003
Unread 22-03-2016, 08:00
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
As an engineer in the truck-industry, I've taken Panther Robotics 1108 in a different direction. We use steel.
It costs about half as much, its half-again stronger than aluminum and if it bends, we can just bend it back without losing strength.
We have a flux-core wire-feed welder in the shop, which is inexpensive to operate and the kids learn to make some great looking welds. Add a bracket? don't need to drill and bolt--just weld it on! Also note, we've never had the money for aluminum welding.
Mostly we use 1/2" x 1/2" x 0.062 wall thickness square section tubing, but also on round parts we use EMT conduit. All available at the local farm store or Home Depot in the city. Also cheap at mcmaster.
Takes up less room too. Can't imagine building in 1/2" tubes in aluminum. Would fold like tinkertoys. Steel is super strong.
And oh-yeah--our robot weighs 105 this year. No lightening holes either. Yes, steel is heavier, but we just use less.
I remember aluminum robots put together with rivets--they were always rickety and wobble. These are solid.
Nirnaeth Nirnaeth is offline
Coach/Mentor
AKA: Michael Liang
FRC #6367 (The Brooke High ElectroLights)
Nirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud of
We use 1x1 T-slotted extrusion. Never had a problem.
Lead Mentor - Team 6367 - The Brooke High ElectroLights
Former Mentor - Team 5969 - The English Skunkworks
Former Mentor - Team 1754 - The Excel Nitro Knights
Unread 22-03-2016, 08:10
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
There's different levels of frames depending on experience, machining capabilities, and CAD use.
Kit Frames.
Hand Built with Alluminum Cross Sections
Machined Alluminum Cross Sections
Machined and Welded Alluminum Cross Sections
Sheet Metal Waterjeted (Or CNC Milled) and bent/riveted
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 22-03-2016, 08:28
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
We use various materials based on its application.
2 x 1 Aluminum tubing:
  • Drivetrain
  • Some structural components, especially those that need a bearing hole
1 x 1 Aluminum tubing:
  • Assemblies that need to be strong but are not structural in nature
  • Thin wall versa-frame for low load applications
Aluminum Sheet (1/8" and 1/4"):
  • Gussets
  • Mounting brackets
  • Other applications where a box tube is overkill
Lexan:
  • Usually for aesthetic uses
  • Can be pretty useful if you are creative with it (bend with heat gun for various shapes)
Unread 22-03-2016, 08:30
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
In addition to KoP Chassis parts, we used Vex versaframe, 2x1x1/8" aluminum channel, and 1-1/4"x1-1/4"x1/8" channel this year.
You are less likely to crush tubes if you use blind rivets rather than bolts. You will need about twice as many, but they're much lighter than bolts and don't crush tubes.
The only place we usually use steel is where we do use bolts and nuts, a few shafts. chain, and internals of COTS items.
We made a few parts out of a rubbermaid garbage can this year. Not for structure, but it worked well keeping the cheval de frise out of our robot, and if we'd had a lot of trouble running over boulders, we had figured out a flap on the front made of rubbermaid to push boulders away but allowing us to use the wedge for climbing over obstacles.
Unread 22-03-2016, 08:40
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
1/16", 1/8", 3/16" and 1/4" 6061 Aluminum plate can be found on our robot. We lay a 4'x4' sheet down on the CNC router bed of whatever thickness we need and cut it from there. One day we'll learn how to CAD metal bends properly, and when we do... look out
Our tubes are 2x1 VersaFrame and 1x1 regular thin wall 6061 Aluminum.
Our standoffs are made from AM Churro or VEX ThunderHex, for the most part. We also have 1" solid aluminum round turned down to make a complex (but sturdy) axle and orthogonal mount for our intake.
Connectors include #10-32 socket head bolts, 3/16" aluminum rivets and 1/4" aluminum rivets. Since ThunderHex and AM Churro are immediately tap-able for 1/4-20, we also use 1/4-20 x 1/2" length into the ends of those.
Ooh, ouch. Those are fightin' words.... We're 33 matches into our season with no wobble on our riveted drive train frame. Don't get me wrong - we would have loved to weld it this year, but couldn't find a sponsor who could turn it around in time. So rivets have worked really well. The trick: Cleco clamps, and rivets every half inch. If 2 of the holes were precision-drilled, then we were able to get away with hand punch/drill on the others. VersaFrame helps a lot, IMO.
GitHub
Unread 22-03-2016, 09:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We used very little metal on our robot this year, aside from the aluminum kit chassis. Most everything else is wood. We used a few pieces of aluminum strap, and a couple pieces of thick sheet aluminum for corner gussets. We also used polycarbonate sheet for the top and bottom, mostly to keep things such as the defenses, boulders, and other robots from getting into or snagged on the innards of our robot. And there are a few pieces of steel strap.
Unread 22-03-2016, 09:29
BetaHelix's Avatar
BetaHelix BetaHelix is offline
FRC #4646
BetaHelix is an unknown quantity at this point
Our practice bot was almost entirely made of .075 steel plate, and it was underweight. Our main bot had .090 aluminium side plates and was 5lbs lighter. We also had steel backed bumpers (19.6lbs per pair!)
Unread 22-03-2016, 09:37
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
We use mostly 3mm aluminium with some similar steel portions where extra reinforcements are needed. For main support structures we usually use 25x25mm SHS, although apart from the drivetrain not much of that was required this year for us.
Most of our parts are bent into shape as sheet metal, however some 90 degree joints (such as our shooting shroud) are riveted (or even welded) into place. Our rhino plates this year are 3mm with supporting churros and SHS to prevent bending and to hold them firmly in place.
Our robot last year was the stock base with a 3mm steel baseplate. Our 'A frame' lifting guiderails were 25x25, 3mm steel SHS, welded into a slanted A frame and bolted to the chassis.
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 22-03-2016, 09:44
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Vast majority is 1x1 and 1x2 Versatubing. We do have some 3/4x3/4x1/16 tube this year.
For plate we mostly use 0.090" 6061, with the occasional 0.040" for light brackets as we can bend it in house. We do have 1/4", 1/2" and even 1" thick AL on the bot this year.
Most hex shafts are AL from VEX, though we do use some steel hex from McMaster. We tried the Thunderhex and I'm not sure if it was just the oversized batch but it was a nightmare to work with and we won't be going back.
We rivet most everything and get critical pieces welded by our local sponsors.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 22-03-2016, 19:04
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
lets see, this year involved:
1/4x 4" flat bar for the intake pivot and motor mount. (6061)
1/16" 1x1" tubing to support and making up the intake frame (6061)
Piano hinge for anything operable in the robot that was not powered by a motor. (in this case it was to allow us easy access to electronics on the bottom of the robot.
3x3 aluminum angle stock (6061) for PG motor mounts
KOP chassis and bumper mounting kit. (50 series aluminum I believe)
where ever possible tubes were connected with gussets and rivets or rivnuts. This makes it much harder to crush the tubing.
and a metric but load of polycarbonate in 1/8" and 1/4" thicknesses. This makes up almost all gussets and the belly pan of the robot that was cut then thermoformed to fit the chassis so it wraps up the front and back in one continuous piece.
and some trace amounts of aluminum bar stock in rectangular and round flavors for spacers and mounting bosses for the tubing where it needed to T into a flat plate.
