Go to Post 27 ft/s? They must really "Rush" around the field - Michael Corsetto [more]
Unread 22-03-2016, 08:33
carsonRadtke's Avatar
carsonRadtke carsonRadtke is offline
FRC #0706 (Cyberhawks)
carsonRadtke is an unknown quantity at this point
USB to Ethernet Adapter For Competition
Team 706 is wondering if there would be any issues with using a USB to Ethernet adapter in a USB 3.0 port on our driver station computer.
Unread 22-03-2016, 08:37
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: USB to Ethernet Adapter For Competition
A couple teams at CIR used USB to Ethernet adapters with out problems. One of them was noticably slower to intially connect to the field. After initial connection was established it worked fine.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Many teams use the USB adapters on their driver station laptops. Just be sure that the drivers are installed and all other adapters are disabled through the network and sharing center.
I'm right 90% of the time, so why worry about the other 3%?
Unread 22-03-2016, 09:56
Thank you kylelanman and Cecil, I appreciate the quick reply. We will try this for our competition. Thanks!
