Go to Post Our safety manager isn't allowed to use the power tools, because he used a drill as a pointing device. - daniel_dsouza [more]
Unread 22-03-2016, 09:46
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
Re: Sticky Fault?
Since it only happens in a given Autonomous mode, I would assume this is a code issue. In a regular match (during Teleoperated), do you change the state of the PCM in any way similar to your High Goal auton?
It sounds to me like 1 of 3 things:
a) Your compressor is faulty and/or not connected.
b) Your CAN bus is not connected properly to the PCM
c) Your CAN bus is being over utilized. Check the Driver Station Logs for CAN % utilization.
A and B both come from the CTRE PCM Users Manual
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
