Go to Post The robot was spinning, I dont have the energy to spin like that. - Joe Menassa [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 30-01-2016, 18:48
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
Re: ANNOUNCEMENT: Analog Devices FIRST Sensor Donation
Is there any information anywhere concerning which SPI port the Accelerometer and Gyro use? I know from the RoboRIO documentation that there are four total and I know that the board just uses CS0 and CS1 but which is which?
Unread 31-01-2016, 00:26
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
The default constructors in wpilib use the correct ports. The ADXL362 accelerometer is on CS1, the ADXRS450 gyro is on CS0.
For more details, the full board schematics are here: https://github.com/juchong/FRC-Gyro-...RevB%20SCH.pdf
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 31-01-2016, 21:21
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
chadr03 has a spectacular aura aboutchadr03 has a spectacular aura aboutchadr03 has a spectacular aura about
Is there a cable that can be used to extend the accel and gyro away from the roborio? We would like to use this, but our design has the rio in a vertical orientation and it would be a challenge to move. If we had a cable that would allow us to position the gyro as needed that would be great.
I just have not been abe to find any kind of a 8 pin SPI cable online, but I'm probably just not looking for the right thing.
Unread 31-01-2016, 22:07
WPILib Developer
The connector is a 10 pin 0.1" pitch IDC ribbon connector, and you need 0.05" pitch 10 conductor ribbon cable. Look at DigiKey parts ED10500-ND (female connector), MPK10K-ND (male connector), and AE10G-5-ND (5' ribbon cable). Even easier, DigiKey also sells premade assemblies such as H3AWH-1018G-ND (1.5') and H3AWH-1036G-ND (3.0').
Also worth noting is the fact the sensor is a 3-axis one, so you could vertically mount it (if it's rigidly mounted and actually vertical) and just read different axes.
Unread 01-02-2016, 00:50
chadr03's Avatar
Thanks that is exactly what I needed and would have never known what to look for.
Unread 01-02-2016, 17:06
AKA: Raa'Shaun H.
Thanks! I was looking for a document like that but, I couldn't find it.
Unread 04-02-2016, 09:40
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
These are both pretty cool! The FRC Gyro & Accel board is working pretty well for our needs so far.
Any idea where one could buy a spare or two? Thanks.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 09-03-2016, 17:48
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
I am looking for a little advice on the 16448 IMU board.
When we first got it we tested things and it seemed to be working as expected (the IMU SmartDashboard widget would move correctly with motion of the IMU). Now that it is install on the robot, it seems not to respond the same. We get what appears to be a rate return instead of a position. The z angle changes as we spin the robot (our robot spins in circles really well), however when we stop the angle returns to 0. It appears like it is tracking the rate and not angle.
Does anyone know of a failure mode where this would happen? Any suggestions?
Thanks
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 22-03-2016, 11:04
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Is there any way outside of FIRST choice we can get the ADIS16448? Our FIRST choice credit are long gone and would like upgrade to the ADIS16448 for some more complicated autonomous routines.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 22-03-2016, 12:38
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Thanks for providing the part numbers! You're correct about the accelerometer providing triaxial output, but the ADXRS450 gyroscope only outputs a single axis (Z when mounted horizontally).
- Bryce
Great to hear!
Unfortunately we're not able to provide any additional IMU or Gyro/Accel boards. The only boards available today are the ones in FIRST Choice stock. These sensors were donated to FIRST by Analog Devices and cannot be sold since that would breach our agreement. There are plans to have more sensors made available to teams in future seasons, but unfortunately the only way to get an IMU or Gyro/Accel board is to purchase it with FIRST Choice points.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 22-03-2016, 12:40
juchong's Avatar
Electrical Engineer
AKA: Juan Chong
Thanks
Hi! You may be accessing the raw sensor outputs instead of the integrated sensor outputs. If you're using LabVIEW, you'll want to access the sensor using the Gyro Angle or AHRS Angle vi's.
Unread 02-05-2016, 16:35
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
My team currently uses the ADXRS450 this season and we loved the performance.
I talked to some teams at worlds that used the ADIS16448 and had really good success with this. We are really wanting to try this sensor out for off season project. Does anyone by chance have a spare one for sale now that the season is done?
2016 Tesla Division Finalist
2016 Central Illinois Regional Finalist
2015 Newton Division Finalist
2015 Newton Quality Award
