Go to Post Whatever you do though, don't get into an "us versus them" mentality with your mentors. They are there to help. - Bongle [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 22-03-2016, 13:27
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
The USB tether does not work
After almost missing a match because we were waiting for our radio to boot so we could reset some things on the robot we decided that it would be a good idea to investigate the use of the USB tether option with the roborio as the rio boots up significantly faster than the radio. Everything I have found indicates that the rio should just connect as it does over wifi or ethernet, however this is not the case. I cannot ping the roborio over usb nor get any sign that it connected except the tone that sounds when you connect any usb device to the computer. All that said we can connect reliably over ethernet and wifi, for whatever that is worth. Any assistace would be appreciated. The roborio has been imaged recently. We are using a Dell Latitude laptop running Windows 7 32 bit and we do have the most recent update to labview
I didn't break it... this time.
Unread 22-03-2016, 14:02
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
Re: The USB tether does not work
Is the wifi turned off or disabled on the computer?
Can you start the roboRIO imaging tool and see the roboRIO using the USB connection?
Unread 22-03-2016, 14:39
AKA: Tim W
Yes, I have turned off the wifi and there is no other internet connection, I did try to see the rio with the imaging tool over the usb cable and was unsuccessful
Unread 22-03-2016, 14:55
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Are you able to ping 172.22.11.2? I believe that is the IP address the roborio assumes over USB.
I win! XD
Unread 22-03-2016, 14:56
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is online now
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Try a different usb port. Does your computer recognize the Rio as a device? Try installing/reinstalling the latest software package.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 22-03-2016, 15:45
AKA: Tim W
I am not able to ping 172.22.11.2
It does recognize it as a device and I just looked and found that it is not functioning because the computer cannot find drivers for the device.
does anyone know where I can find those drivers
Unread 22-03-2016, 15:50
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
We USB tether exclusively. I thought the roboRio drivers were install during the Labview update. I suggest you review all driver station settings listed in this guide.
https://wpilib.screenstepslive.com/s...rio-networking
Unread 22-03-2016, 16:08
AKA: Tim W
it says that it is supposed to have the drivers, but it didn't seem to work when we installed that update
Unread 22-03-2016, 17:58
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
We had this problem earlier this season and found we had to reinstall the update suite to get the drivers working.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 22-03-2016, 22:31
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Did you try a different USB cable? Does the roboRio have good power?
The drivers are installed with the update suite. I think this is where they are:
C:\Program Files (x86)\National Instruments\CompactRIO\Staging\USBLAN
I can't tell for sure, because I don't have a roboRio to plug in here at home. You could try browsing to it and installing the driver manually.
Brian K
Team 1225 Robotics Mentor
Unread 23-03-2016, 11:24
techplex's Avatar
techplex techplex is offline
Blake B
AKA: Blake
FRC #4909 (The Bionics)
techplex is just really nicetechplex is just really nicetechplex is just really nicetechplex is just really nice
Why not just plug an ethernet from the RoboRIO to the Laptop? Skip the router and Skip the USB.
Blake
Electrical, Programming and Design
Creator FRC Q&A 2017
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
Unread 23-03-2016, 12:39
JR0405's Avatar
JR0405 JR0405 is online now
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 has a spectacular aura aboutJR0405 has a spectacular aura aboutJR0405 has a spectacular aura about
Is there a difference between using usb or Ethernet?
Unread 23-03-2016, 15:00
techplex's Avatar
Blake B
AKA: Blake
If you use USB you have to have the USB driver for the roborio installed and MDNS installed.
If you use Ethernet you only need MDNS if you don't use static addressing on the RIO.
What I recommend is set the IP address on the RoboRIO to static 10.TE.AM.2 and then you set the IP on your computer to 10.TE.AM.5 and then plug the computer direct to the RIO and it will start communication almost instantaneously.
Blake
Unread 23-03-2016, 18:22
Brian Michell's Avatar
Brian Michell Brian Michell is offline
Timelord and programmer
FRC #5416 (TaRDIS)
Rookie Year: 2015
Brian Michell is an unknown quantity at this point
Silly question, but are you using a USB type B in the roboRio? That was something that tripped up our team during our rookie year. We spend forever looking for a double sided type A USB cord!
