Go to Post In my book the team building experience of the kids training the engineers in the operations on the field would be invaluable. It might not get a trophy but you win far more in the long run. - Wayne C. [more]
Unread 22-03-2016, 13:41
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Autonomous Help
In your second frame of your sequence, you don't actually tell the wedge arm motor to stop. You need to set output to 0 for that device for it to stop, otherwise it just keeps doing the last thing you told it.
Really, you should have three sequence frames here.
1. One second wait and the code you have for the wedge arm motor,
2. Five second wait, the wedge arm motor stop, and the drivetrain start
3. Stop the drivetrain.
Right now, your first frame ends as soon as you set the motor. If you put a wait block in that first sequence frame for 1 second, that will get it to last a full second. This doesn't have to be connected to any of the other items in that block -- Labview won't leave that frame of the sequence until everything in it has completed. What you're doing in your second frame would have worked without the sequence structure.
