Go to Post ...Well also I'm just hooked on FIRST. (I swear, I can quit whenever I want!) - CENTURION [more]
Unread 22-03-2016, 15:31
adammiller3122's Avatar
adammiller3122 adammiller3122 is offline
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
Re: SuperScouter For FRC -- A Multiplatform, Extensible Scouting System
I have noticed a critical bug that occurs for us. If you take a look at the match data, the first 2 columns are moved over. That will not work so well, unless we want to edit the csv before analyzing. I have not noticed that with the pit data at all.
I have also noticed that when adding a multiple choice question, it says text box id, instead of something like multiple choice.
Something else that I noticed, is that when exporting the data, the way that data is put into the csv is that in between multiple choice options with the allow multiple checked, all checked options are just squished together - as opposed to having a space between them. They are also not always in the same order. They are in the order that they are clicked. That could cause some issues with analyzation for some. Those are just what I remember.
File Type: zip bug.zip (684 Bytes, 2 views)
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
FTC Team 10493: RoboWarriors (mentor)
homepage: newulmrobotics.com
