what are you using for the gyro?
What did you use instead of the gyro in the kit? I bought the evaluation version of the Analog Devices ADXRS150 gyro. Its mounted on a very small PCB that is the same size as a regular 20 pin DIP IC. The part number is ADXRS150EB. The standard max velocity is 150 degrees per second, but the rate can be increased by adding a resistor up to 300 degrees per second. It also includes an onboard low-pass filter for some noise rejection. I was just wondering if anyone has used it.
| Need a FIRST Robotics control system | kershawrobotics | General Forum | 3 | 07-07-2003 09:49 |
| Scoring system for 2004? | DougHogg | General Forum | 11 | 16-04-2003 20:57 |
| control system worth more than $500 | archiver | 2001 | 8 | 24-06-2002 02:00 |
| New Innovation FIRST control system and the dashboard | archiver | 2000 | 0 | 23-06-2002 22:15 |
| Ok, how much is the control system worth? | archiver | 2001 | 6 | 23-06-2002 22:05 |
