Go to Post ...thinking and learning never go out of style. - Rick TYler [more]
  #46   Spotlight this post!
Unread 22-03-2016, 16:11
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Re: Lights to help aim
Originally Posted by Michael Hill View Post
I've been wondering...is there an advantage to using a flashlight rather than the LED ring? Is it just a cost/availability thing or is there some technical advantage as well? #KnowsNothingAboutCV
Who said anything about using the flashlight for vision processing?
  #47   Spotlight this post!
Unread 22-03-2016, 16:14
Michael Hill's Avatar
Is it used another way?
  #48   Spotlight this post!
Unread 22-03-2016, 16:18
You set up the light so it is lined up with where you shot goes. Then for shooting all you have to do is line up the light with the high goal and fire. You get an easy way to line up your shot without having to use vision processing.
  #49   Spotlight this post!
Unread 22-03-2016, 16:29
Then what's the point of the light? Drivers can see the goals with the camera already.
  #50   Spotlight this post!
Unread 22-03-2016, 16:39
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
We use ours like a laser sight on a gun. We don't use it with the camera at all.
461 Westside Boiler Invasion
45 Technokats
  #51   Spotlight this post!
Unread 22-03-2016, 16:41
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Often drivers don't like looking down away from the field....
  #52   Spotlight this post!
Unread 23-03-2016, 09:49
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
Originally Posted by Coach Seb View Post
I bought the exact same thing that was recommended by apm4242....
- LED Flashlight with zoom
- DC-DC Voltage Converter/Regulator
- Spike Relay
I'll check the voltage again... last night we had 10V on the spike relay, i did not check the voltage after the converter yet as we assumed we fried the spike... but yet between test it worked... still wondering...
I tried sizing a resistor that would work for the Hausbell LED Flashlight but could not find the LED data sheet. I don't have the flashlight in front of me, so I couldn't try to pull a model number off of the LED. Going off of what CREE offers, I tried to find an LED using the flashlight specs (300lm, size, Q5, etc) and found a few LEDs with a forward voltages of between 2.9 V and 3.5 V and forward currents of 1000 mA for white light.
Using the equation R = (Vs - Vf)/i where Vs is supply voltage (3.3 V in my case), Vf is forward voltage, and i is current, gave resistor values between 0.4 Ohm and 0 Ohm. From what I have read and from how the math works out, you don't need a resistor if the supply voltage is less than the forward voltage and there are no voltage spikes (assuming the LED lights up at all).
I'm a little out of my wheelhouse with this stuff. Hopefully someone with a little more experience will come along and offer some wisdom...
Cree Components
Similar LED Data Sheet 1
Similar LED Data Sheet 2
LED Current Limiting Resistors Tutorial
  #53   Spotlight this post!
Unread 23-03-2016, 09:54
Ninjastahr's Avatar
Ninjastahr Ninjastahr is offline
FRC Member
FRC #3928 (Team Neutrino)
Ninjastahr is an unknown quantity at this point
Why not just use a beambreak sensor? They have the range for it* and would be able to tell you exactly when you are pointed at the goal, and are fairly easy to see.
*they are rated for use at that range, but I have never seen it done
  #54   Spotlight this post!
Unread 23-03-2016, 12:11
45 Alumni
AKA: Peyton Yeung
We use ours for telling us where we are pointed at the goal. The goal doesn't have much room for horizontal misalignment so the flashlights shows us left to right where our shot will go. It seems to work well because we were typically shooting with an 85-90% accuracy.
45 Technokats
  #55   Spotlight this post!
Unread 23-03-2016, 12:20
stoddard stoddard is offline
FRC #5712
stoddard is an unknown quantity at this point
How do you wire a flashlight to the robot, this is our second year and there is still a lot of new stuff for us to learn?
  #56   Spotlight this post!
Unread 23-03-2016, 12:26
Ninjastahr's Avatar
FRC Member
Why not use a camera and a vertical line on the dashboard output?
  #57   Spotlight this post!
Unread 23-03-2016, 12:45
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
My team uses Labview and could use some assistance in setting up the use of LED lights to help aim. Our idea was to be able to determine when our robot was at the right distance from the castle wall to shoot. We have the LED mounted on our camera but are not able to set it up in Labview. IF you can help walk us through this, email me at ahudson@adairschools.org and I will forward it to our programmer and he can communicate with you better than I can.
  #58   Spotlight this post!
Unread 23-03-2016, 12:48
Darkseer54's Avatar
Darkseer54 Darkseer54 is offline
Former Controls Captain and Driver
AKA: Zach Kaplan
FRC #1086 (Blue Cheese)
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
Because that would involve the complexity of programming a camera and running some form of vision processing. Using a light involves wiring a flashlight to a spike, and programming that spike to turn on and off on command.
Driving wise, the difference is you are in full control of the robot at all times, whereas if you were using a camera you have to relieve your control of the robot to your control loop. For teams without a strong programming group (or even teams with a strong programming group who just prefer to avoid sensors) a flashlight is a much simpler way to align your shooter rather than going through the trouble of using a camera.
2014: IRI on a losing record.
  #59   Spotlight this post!
Unread 23-03-2016, 13:09
Ninjastahr's Avatar
FRC Member
No, I mean just looking at the camera to see the goal on the driver's station without processing the images. You can just have a set line of black pixels (using the NIVision.imaqDrawShapeOnImage() or imaqDrawLineOnImage()? in Java) in the center of the image, line it up manually with the center of the goal, and shoot the ball into the goal. It's really just as easy as setting up a spike.
  #60   Spotlight this post!
Unread 23-03-2016, 13:12
Ninjastahr's Avatar
FRC Member
Are you having trouble using the LEDs themselves, or with getting the position of the goal using the camera?
