Go to Post However, it is logistically impossible, so it's now just a joke. - EricH [more]
Unread 22-03-2016, 19:04
Johncvt Johncvt is offline
FRC #0910
Johncvt is an unknown quantity at this point
Unhappy Re: Anyone else having problems contacting West Coast Products?
We had issues with the WCP SS gearbox at our tournament over the weekend (aluminum drive gears wearing out and locking up). Tried emailing them on Sunday and tried calling, no response yet.
Unread 23-03-2016, 09:24
zsm150's Avatar
zsm150 zsm150 is offline
AKA: Zack Moore
FRC #0314 (Big Moe)
zsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to behold
Do you check that your cims are in the right position for the size pinion you are using? We had a similar problem in week 2 turns out one of our students put the cims in the position for a 12T pinion but we are using 11T.
Frog Force Team 503 Drive Team 2013-2015
http://www.frogforce503.org/
Big Moe Team 314 Drive Coach 2016-?
http://www.bigmo314.com/
Unread 23-03-2016, 09:42
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
I agree with your sentiment, but factually, both the 11T and 12T pinions use the in-board CIM positioning holes, whereas the 13T and 14T pinions have the CIM bolt to the out-board holes. Both the SS and DS do this. I know this first hand because the students building our gearboxes got 3/4 CIM bolts correct, but the 4th bolt caused us to destroy 2 pinions and a 42T gear the Wednesday before our 1st district. Hidden under electronics so we didn't notice until they were toast. Thank God it didn't happen AT our district event.
Sadly, we had similar problems when ordering through WCP. One of our ordered dog gears had the wrong bearing press-fit inside it (we ordered 2 identical gears and received 1 round and 1 hex), but communications took over a week to go through. By the time they finally got back with us, we had already purchased and received replacement parts from an alternate source.
I love their products, but they SERIOUSLY need to hire more people to beef up their customer service department.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2016: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 23-03-2016, 11:00
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
The 12T and 11T pinions use the same "inboard" mounting holes on the CIMs.
We had the locking issue at our event on practice day, and eventually it came to the sheered off 50T gear. Looking at the gearbox it was obvious the issue was that the CIMs were mounted on this outboard hole. We thought at the time this was due to incorrect assembly, proceeded to replace it with a steel 50T gear, putting the CIM's in the inboard hole.
After inspecting the other gearbox, it appeared atleast one of the CIM's were in the outboard hole. Sure enough the next match (thankfully our last one of the day) it started locking, and the gear had sheered right off. This gearbox we know for a fact was infact assembled correctly with the CIM's mounted to the "inboard" hole. (We know this because this process was recorded on video for a reveal video, and it's clear that the gearbox was infact assembled using the inboard hole.
This leads us to suspect that perhaps the CIM's are able to shift from inboard to outboard throughout use without the bolt coming out?
Both gears have been replaced with steel gears, and red loctite was used on the inboard/outboard CIM mounting bolt.
I've attached a picture of one of the gears - at least what is left of it.
http://i.imgur.com/mVv31n4.jpg?1
Personally, I'd rather see a separate mounting hole on the gearbox plates rather than two holes side by side. This issue cost us an RP, and a match. We're open to talking to WCP's Engineers to see what can be done. We haven't emailed them yet because our robot is bagged, and understand there is a huge backlog on emails.
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
