Re: Your tall opaque robot is now illegal
Originally Posted by waialua359
Jon,
we were told by the refs at the Lake Superior event during the semifinals to secure our bumper a little higher on one of the corners of the robot because they said it was too low (sagging). We were told to fix it or sit out. I didnt have a tape measure on me, but we used a wood screw drilled through our frame to secure it temporarily until our final matches were over. Yet, we passed inspection.......twice.
Hi Glenn,
I'm not sure if the Head Ref was involved prior, but from what I witnessed (I forget which round), a field-side RI noticed that 359's bumpers had zip-ties around the bumpers and notified the LRI. The LRI checked the robot on the field and had the drive team remove the zip-ties since these aren't considered a rigid fastening system and aren't part of the legal bumper cross-section. I was on the field next to your robot when the zip-ties were removed and it was clear that the front corners were not very rigidly attached. I'm not familiar with your bumper fastening system, but it seemed like something must have broken or loosened during a previous match and the zip ties were added as a temporary fix. The LRI allowed 359 to play that match and required that the bumpers be more rigidly attached for the next match, which is when you added the wood screws. Maybe during that same match the Head Ref also noticed them sagging and also gave you a "warning," or maybe the Head Ref had noticed them sagging after the fastening system loosened and that's what prompted the zip ties, but either way, this does seem like an appropriate application of G19-1 (and as far as I know, you weren't fouled or disabled, just asked to fix it for the next match).
Mentor, FRC 2052 KnightKrawler: 2008 - Present
Robot Inspector: 2013 - Present
LRI, Minnesota 10,000 Lakes Regional: 2016
Reason: fixed typo
