Go to Post After all, life is what you do outside of FIRST. No wonder it's so short. - Vashts6583 [more]
  #61   Spotlight this post!
Unread 23-03-2016, 13:22
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Re: Lights to help aim
Originally Posted by Ninjastahr View Post
No, I mean just looking at the camera to see the goal on the driver's station without processing the images. You can just have a set line of black pixels (using the NIVision.imaqDrawShapeOnImage() or imaqDrawLineOnImage()? in Java) in the center of the image, line it up manually with the center of the goal, and shoot the ball into the goal. It's really just as easy as setting up a spike.
As stated above, most drivers don't like looking down at the driver station. So either you'd need some form of HUD so that the driver can look at the robot and view the camera at the same time, OR simply use a flashlight to shine onto the goal to show that the robot is aligned or not. Also, any lag in the camera image showing on the dashboard will affect your accuracy. Both can be viable ways of doing it.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
  #62   Spotlight this post!
Unread 23-03-2016, 15:42
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Why not use a camera and a vertical line on the dashboard output?
That would require the drivers to take their eyes off the robot.
461 Westside Boiler Invasion
45 Technokats
  #63   Spotlight this post!
Unread 23-03-2016, 15:48
No, I mean just looking at the camera...
First, the camera image is not always immediate. If you try to steer your robot by looking at the screen, you're very likely to overshoot the target direction while you try to line things up. Second, it's just a whole lot easier to not have to look at the laptop screen in order to aim your robot.
Basically, a moving spot of light on the actual tower, where the driver is already focusing his or her attention, is much simpler to deal with than a flat and slightly delayed image of the tower on the laptop.
  #64   Spotlight this post!
Unread 23-03-2016, 16:12
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Originally Posted by stoddard View Post
How do you wire a flashlight to the robot, this is our second year and there is still a lot of new stuff for us to learn?
Did someone order cheesecake?
What you will need for just the flashlight.
A 12 volt flashlight
A spike relay.
To augment the flashlight so it has a more focused beam or less light showing overall you can use
Black electrical tape
A focusing lens (a lot of science departments at schools have these for various experiments)
We use this 12 volt flashlight wired to a spike relay. This flashlight is nice because it is one where the light can pivot and it really helps that we don't need to angle the entire thing in order to aim it properly. Earlier in the build season I also borrowed a focusing lens from the physics department at the school I mentor with (most science departments at schools do an occasional light activity and should have one otherwise they can be purchased through a ) and after measuring the optimal distance for placement of the lens had a student cad and 3D print something for a smaller flashlight to hold the lens at the correct distance. We reused that mount with zip ties and tape instead of cading a new one for the flashlight I posted above due to time constraints. Since the lens we have is smaller then the flashlight we used black electrical tape to reduce the amount of light that shines through hopefully reducing the chance of it being distracting. Wiring the flashlight was simple because it is done through the spike to the battery leads which gives you the ability to turn them on and off.
With the exception of the 3D printed mount (which in all fairness you can use any sort of material to mount the lens to the flashlight) everything is all COTS and takes minimum work to put together.
Cheese it up!
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
  #65   Spotlight this post!
Unread 25-03-2016, 19:18
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
I am guessing there is some reason that you can't simply use a motor controller outputting 3 Volts? I would assume this was the simplest way to power a 3V light, but the fact that no one has suggested it makes me think it wouldn't work.
  #66   Spotlight this post!
Unread 25-03-2016, 19:48
The reason you can't use a motor controller outputting 3 volts is simple: You can't get an FRC legal motor controller to output 3 volts. It's either providing no voltage or full battery voltage (in one direction or the other). Inductive loads like a motor will average out the pulse-width modulated battery voltage, but a 3 volt flashlight is likely to be very unhappy with even a brief application of four times the expected voltage.
  #67   Spotlight this post!
Unread 27-10-2016, 20:13
Codster39221924's Avatar
Codster39221924 Codster39221924 is offline
AKA: Cody Smith
FRC #2130 (Alpha+ 2130)
Codster39221924 is an unknown quantity at this point
Hi Mike i'm Cody i was wondering how you guys mounted the flashlight? I would like to hear how you guys did it. Please reply asap. Thank You.
  #68   Spotlight this post!
Unread 27-10-2016, 20:15
AKA: Cody Smith
Originally Posted by Michael Corsetto View Post
What height was the beam at? I could maybe see their point if it was pointed at eye level. We aimed our beam to hit the very top of the tower, but that was more out of convenience for mounting than anything else.
-Mike
  #69   Spotlight this post!
Unread 27-10-2016, 23:05
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Might be better to PM him if you need a response from him specifically.
