Go to Post Coming up next on Pimp My Ride.....Yo man, here is the real deal. A two-oh-oh-six Segway I-one-eighty, with stock rims, stock fenders, and two 3 horse motors that red-line at twelve point five miles per hour. Get ready, because I'm going pimp this ride! - artdutra04 [more]
Unread 23-03-2016, 15:47
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
PID controller with camera.
Hi, I am working on a command that auto aligns to the center of the goal by rotation and we are getting some overshoot with it so I am implementing a PID control loop. However, the PIDController class takes in a PIDSource and outputs a PIDOutput, so I wrote wrapper classes to write and read raw values (like ints and floats) to a PIDOutput and PIDSource. However, when I call the Enable function on the controller, it instantly crashes. I don't really know why this is happening.
My code is here:
https://github.com/team2053tigertron...lignCenter.cpp
Any help is appreciated,
Drew
Unread 23-03-2016, 16:11
nowireless nowireless is offline
AKA: Ryan Sjostrand
FRC #3081 (Robo Eagles)
nowireless is an unknown quantity at this point
Re: PID controller with camera.
It looks like you are using the wrong shared pointer, both Robot and RobotMap they have a shared pointer named visionAlignPID. It looks like the one in Robot does not contain a pointer, while in RobotMap you set the visionAlignPID shared pointer to a PIDController.
I think you should change
 Robot::visionAlignPID.get()->Enable();
to
RobotMap::visionAlignPID.get()->Enable();
Unread 23-03-2016, 16:27
jreneew2's Avatar
AKA: Drew Williams
Alright, it doesn't instantly crash now, but when I call PIDWrite() it crashes. Am I inheriting the PIDSource wrong?
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
It looks like you're using a system that centers itself in the pixel. Jared Russel has talked before about why this isn't a good idea, but the general complaint is that a camera has too high of a latency (even when plugged in via USB or equivalent) to be used in a PID loop. Instead of calculating the offset from the center, try and calculate values that might help you align. The distance, azimuth, and altitude are values that you might be most concerned about.
