Go to Post I say we all stop flaming and pointing out what went wrong or what bad calls were made and start pointing out how much fun we all have at the regionals and what FIRST actually has done for us. - burkechrs1 [more]
Unread 23-03-2016, 11:16
Firgreen Firgreen is offline
Kevin Zheng
FRC #2834
Firgreen is an unknown quantity at this point
Defense Robots
Hi!
I have been trying to filter through data in order to look for common trends among defensive robots and I want to confirm my findings. If you have seen a chiefly defensive robot in your competition, could you comment below, as well as what their mechanism was for defense?
Thanks!
Unread 23-03-2016, 11:27
logank013's Avatar
logank013 logank013 is offline
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
Re: Defense Robots
I won't say their main intent for their robot is defense because it probably isn't but team 447 has been playing great defense these last 2 weeks. Now in qualifications, they've been showing off their good low goal shooter, but the last two weeks in eliminations, they've shown that they can cause some defensive damage.
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
Unread 23-03-2016, 11:30
Amit3339 Amit3339 is offline
B B BumleB
FRC #3339
Amit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to beholdAmit3339 is a splendid one to behold
Re: Defense Robots
At the playoff matches of the Israeli Regional Team 4744 'The ninjas' had a net stretched on the side of their robot. It wasn't complicated to build but it did the work!
I'm hoping we will upload full field-view soon so you could see the effectiveness of this mechanism
2016- Team Captain, Driver & Programming Crew Member
Championship Curie Sub-division Winners| Curie division
Regional Winners | Israeli Regional
2015- Driver & Programming Crew Member
Championship Carson Sub-division Winners| Carson division
Excellence in Engineering Award sponsored by Delphi | Israeli Regional
2014- Driver & Programming Crew Member
Unread 23-03-2016, 11:35
sagrossm sagrossm is offline
AKA: Sam
FRC #5712 (Hemlock's Gray Matter)
Rookie Year: 2016
sagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to all
Re: Defense Robots
From what I've seen and assume, teams aren't making specific mechanisms for defense. A fast, sturdy robot that can quickly block robots paths or knock them out of their alignment for shooting high seems to be what is needed for good defense. I believe if you can achieve that then you will have a solid defensive robot.
Unread 23-03-2016, 11:42
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Defense Robots
Team 3061 played excellent defense against 16 and 3310 during Rock City quarterfinals. The didn't have a blocker, and wouldn't have needed one.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Re: Defense Robots
2656 had a bolt-on shot-blocking-net that we deployed for two matches at Greater Pittsburgh. We made sure to be inspected with it installed, and then removed it for the matches we wanted to remain Low Bar capable.
It didn't get to block any shots really, but it was plenty tall enough that it could have. It was fun to watch!
Here's a video of Q81, the second and final time we sent out the net.
FRC 2656 | FTC 5526 | VEX 9656
Unread 23-03-2016, 11:47
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of lightNShep98 is a glorious beacon of light
Re: Defense Robots
Our robot was not designed to play defense, but our climber arm is a decent goal-blocker, and we have a fast robot with above-average length to really get in the way of opponents. If you watch our later WPI matches, you can see us following alongside an enemy robot to cause as much trouble as possible for them to get to their preferred position.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 23-03-2016, 13:55
cgmorse19 cgmorse19 is offline
FRC #1138 (Eagle Engineering)
Team Role: Photography
Rookie Year: 2015
cgmorse19 is an unknown quantity at this point
Re: Defense Robots
I don't have a lot of specific teams that play great defence except 330 but i took note that many of the teams like ours and 330's usually have a good defence when they have a west coast 6 sim drive base
Unread 23-03-2016, 16:04
M217's Avatar
M217 M217 is offline
#TSIMFD
AKA: Muhammad Mousa
FRC #3419 (Rohawks)
Team Role: Tactician
M217 is on a distinguished road
Re: Defense Robots
Agreed; a sturdy drive train with good traction is by far the most important mechanism for playing effective defense. The second-picked defense-bot is a trend that seems to be continuing and growing this year, and all the best ones are those with enough pushing strength and maneuverability to stop the opponent from scoring.
Our own second pick in Tech Valley, team 633, was a low robot incapable of blocking shots but they managed to defend very effectively by virtue of having skilled drivers and a lot of torque. Also, knowing the defense rules is certainly very important...
Unread 23-03-2016, 16:14
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Re: Defense Robots
Originally Posted by Firgreen View Post
Hi!
Thanks!
What exactly are you looking for?
From my experience most defensive robots can be put into two categories.
Passive defenders who defend using something already on the robot in conjunction with the drive base.
Active defenders who have powered defensive structures.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
