Go to Post The jags are powered with magic... - Aren Siekmeier [more]
Unread 21-03-2016, 19:59
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
N MS HD-3000 Camera Code (LabView)
The attached code is beta software. I am only releasing it at this point due to the demand for such code. I have only tested it with up to 4x MS HD3000. It has the following capabilities:
1) Support for N Cameras. The only limit is labview, the OS, or USB bandwidth limits.
2) Capable of transmitting the images across the network to a dashboard using only one TCP/IP port.
3) Port hopping in the event a port is blocked (input array provides list of ports to try)
4) Allows for reading of the camera on the roborio
5) Allows for configuration of the roborio such that it is suitable for image processing
6) All video modes of the HD3000 are supported
This code is still in beta, expect some bugs. I'm still working on it and trying to make it more robust. Please submit any bug reports to me and explain how you came to it.
This code should be adaptable to other USB cameras but I do not yet know what would be required to do so.
Unread 22-03-2016, 01:14
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Re: N MS HD-3000 Camera Code (LabView)
This looks very interesting. Personally, I'm not really sure how to implement it in our code. I know it's still in beta, but a good tutorial or some kind of document would help a lot.
We're using two cameras on two ports and switching back and forth. This causes a small 2-3 second delay. Is there any delay with your setup?
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 22-03-2016, 05:36
One Eyed Man
The code can stream all cameras simultaneously. Any delay would only come from the time it takes to switch streams on the dashboard from one to the other.
Sorry for the lack of documentation, that usually comes with the release. I've been working on this in my spare time and we've got a competition this weekend.
Unread 22-03-2016, 06:24
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
That's awesome - thanks for sharing
Unread 22-03-2016, 09:20
jojoguy10's Avatar
AKA: Joe Kelly
If it streams all of the cameras simultaneously, does it go over the 7Mbps bandwidth restriction?
And I totally understand about the documentation :-)
Unread 22-03-2016, 13:08
One Eyed Man
Bandwidth usage is dependent on the resolutions you select. We've 2x 160x120 @ 10FPS and 1x 424x240 @10fps streams simultaneously (three streams total) and hit ~2.1 mbps. I don't think it'll be an issue unless you want to go to standard resolutions or 30fps. Also, if you select the appropriate VI (I'll have to check which one) you can enable/disable streams. I need to look at expanding some of this capability in the future when I have more time.
I'll make a note to add a bandwidth counter/monitor.
Unread 23-03-2016, 16:27
teku14's Avatar
teku14 teku14 is offline
http:
FRC #2614 (MARS)
teku14 is a jewel in the roughteku14 is a jewel in the roughteku14 is a jewel in the roughteku14 is a jewel in the rough
There were some files missing in this project after we unzipped it:
Change Camera Configuration.vi
TCP Port Control.ctl
Qualifications Calculations.vi
Unread 23-03-2016, 19:15
bburt2006 bburt2006 is offline
FRC #4632
bburt2006 is an unknown quantity at this point
Hi,
First thank you for posting code! I tried opening it and seems to be missing the "Change Camera Configuration.vi"
Could I please get this missing vi?
Thanks Bill!
Unread 23-03-2016, 22:07
One Eyed Man
Sorry about that! The attached should have all the files.
Unread 24-03-2016, 15:49
Bradley Boxer's Avatar
Bradley Boxer Bradley Boxer is offline
AKA: Bradley Boxer
FRC #0303 (TEST Team 303)
Rookie Year: 2015
Bradley Boxer is an unknown quantity at this point
Thank you for making this!
I seem to still be missing files after downloading your new project:
-Camera Settings.ctl
-38 Video Mode.ctl
Others that aren't having problems: are these files in some other place I don't know where to look for them? Sorry for being a pain in the neck.
Thanks
Unread 24-03-2016, 19:45
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Thanks for the code! My team was looking for a solution for this all season, I hope it will work for us.
I have managed to recreate the missing controls, they were present in the project as regular controls but the actual type def was missing so I fixed it.
The fixed project is attached
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
