Go to Post "which came first, the hamster or the toad?" - dlavery [more]
Unread 24-03-2016, 09:52
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Actual 120 PSI for Storage
The software for pneumatics is pretty sweet - plug everything in, initialize something and away it goes.
The problem is, the cutoff of the automated switch happens anywhere between 110 and 115 PSI. How are teams able to get 120 PSI of storage volume? Is that switch adjustable?
(caveat - I haven't done more than a cursory look over pneumatic rules since 2011, which is when the electronics team took over that duty).
GitHub
Unread 24-03-2016, 09:55
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Actual 120 PSI for Storage
we noticed the same thing. a year or two ago there was a thread that stated that the switches were calibrated in the factory and could not be adjusted by us (even though there is an adjustment screw on the switch). I'll try and search for the thread and repost it here.
found it:
http://www.chiefdelphi.com/forums/sh...nason+swi tch
Unread 24-03-2016, 10:57
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
found it:
Rules on this seem slightly grayer this year. There's not specific prohibition on adjusting the switch, just that it needs to operate to prevent over pressuring the system. There's the general rule prohibiting modification of pneumatic components and there's no exception for adjusting the pressure switch, but there's also no exception for calibrating the pressure relief valve, which is suggested by a blue box later on.
Maybe Q&A adjustment of the pressure switch just to be sure?
Unread 24-03-2016, 10:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The switch can be manually adjusted, however it requires breaking the factory seal around the outside of the switch itself - which has rendered it illegal in the eyes of inspectors in the past. Your mileage may vary.
Unread 24-03-2016, 11:14
Oblarg Oblarg is offline
AKA: Eli Barnett
Try different switches until you find one that is set a bit higher.
As far as I know, there's no way to adjust them.
"The breakfast of champions!"
Unread 24-03-2016, 11:44
wilsonmw04's Avatar
Coach
We tried that and out of 4 that we have we never got one to 120. only 115.
Unread 24-03-2016, 11:49
AKA: Eli Barnett
I can't recall if I've ever actually gotten one set to 120. Some are certainly a lot better than others, though.
Unread 24-03-2016, 11:54
Everyone,
The pressure switch may not be adjusted per R76.
The adjustment is to set the position of the microswitch internal to the assembly for operation. It is set at the factory to overcome the differences in microswitch operation from unit to unit. Through testing, the switch is actually a lot more accurate than it appears, as the gauges used on most robots do not have the precision needed to read 120 psi with any repeatability.
Unread 24-03-2016, 14:15
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The little screw on the side is a locking screw. You adjust the switch by turning the barrel. Once you run out of range, the switch stops working. (which means adjusting to the high side the compressor will stay on.) The part number of the legal switch calls for a set pressure of 115 PSIg rising. So most switches will turn off close to 115 psi. They turn back on based on the hysteresis of the switch which isn't as precise. As Al said, they are nonadjustable by rule.
Unread 24-03-2016, 14:20
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We also have the same issue. Ours usually says 112 PSI.
Unread 24-03-2016, 14:49
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Ours only reaches 105 psi.
Unread 24-03-2016, 14:51
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Most of the ones I have seen turn off between 115 & 112 indicated. I suspect that Nason adjusts them to turn off before 115. Your pressure gauge is almost certainly a class B which are accurate to 2% of span in the middle. So assuming a 160 psi gauge that 112 +/- 3.2 psi.
