Go to Post Only think of Gracious Professionalism as a standard to work toward personally. Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 24-03-2016, 14:15
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Actual 120 PSI for Storage
Originally Posted by wilsonmw04 View Post
We tried that and out of 4 that we have we never got one to 120. only 115.
The little screw on the side is a locking screw. You adjust the switch by turning the barrel. Once you run out of range, the switch stops working. (which means adjusting to the high side the compressor will stay on.) The part number of the legal switch calls for a set pressure of 115 PSIg rising. So most switches will turn off close to 115 psi. They turn back on based on the hysteresis of the switch which isn't as precise. As Al said, they are nonadjustable by rule.
Unread 24-03-2016, 14:20
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We also have the same issue. Ours usually says 112 PSI.
Unread 24-03-2016, 14:49
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Ours only reaches 105 psi.
Unread 24-03-2016, 14:51
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Most of the ones I have seen turn off between 115 & 112 indicated. I suspect that Nason adjusts them to turn off before 115. Your pressure gauge is almost certainly a class B which are accurate to 2% of span in the middle. So assuming a 160 psi gauge that 112 +/- 3.2 psi.
