Go to Post Are you confused yet? - Andy Grady [more]
Unread 24-03-2016, 15:55
sodizzle's Avatar
sodizzle sodizzle is offline
AKA: Brandon Sidoti
FRC #1023 (Bedford Express)
sodizzle is a jewel in the roughsodizzle is a jewel in the roughsodizzle is a jewel in the roughsodizzle is a jewel in the rough
Re: [FiM] Midseason Review
Originally Posted by Zebra_Fact_Man View Post
If I may ask, what were your gearbox problems?
At Waterford we were using the WCP DS Gearbox. We ended up destroying a dog gear, an axle, a shaft collar, and the mounting block.
At Pittsburgh we decided to get rid of that problem and used WCP SS gearboxes. Part of the problem was with the 11t pinions we were using not quite meshing with the other gears. I wasn't there so I can't say exactly what else happened but I believe the CIMS broke through the mounting hole that has 2 positions for the different sized pinions and spread away from the gear.
All that aside, we're ready to come out to Livonia with fixes and improvements and hopefully perform better than ever.
Originally Posted by tr6scott View Post
I have a feeling both TORC and BX will be back on tracks this weekend. Good Luck!
I sure hope so! Good luck to you too!
Proud alumni of 1023
http://www.chiefdelphi.com/forums/ximage.php,qtype=sigpic,auserid=64794,adateline=13  93953662.pagespeed.ic._coysrOV9p.jpg
