Go to Post This is the first (and, if this stuff keeps up, last) time FIRST has allowed high-speed projectiles in years. Please use some common sense, people. - Madison [more]
Unread 19-03-2016, 12:54
Jackson Hogan Jackson Hogan is offline
FRC #5090
Jackson Hogan is an unknown quantity at this point
LabVIEW w/ Ubuntu 14.04
Does anyone know how to install LabVIEW on Ubuntu 14.04?
I tried Wine (Windows Program Loader). That did not work...
Any help is appreciated!
Unread 21-03-2016, 14:33
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
Re: LabVIEW w/ Ubuntu 14.04
http://www.ni.com/product-documentation/52786/en/
The toolkits you'd need to make an installation for FRC work aren't supported on Linux. For software that is supported on Linux, it's for builds other than Ubuntu.
Unread 22-03-2016, 13:33
FRC #5090
Do you know how i can duel boot Ubuntu with a supported os?
Unread 22-03-2016, 14:49
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
I've been able to run a virtual machine with Windows 7 without much issue. I used virtual box.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 22-03-2016, 15:23
FRC #5090
I did some more reading, and found that CentOS is supported by LabVIEW... But i can not figure out how to install it. Any help there?
Unread 22-03-2016, 15:29
FRC #5090
I cant figure out how to install LabVIEW (I didn't specify that in last post)
Unread 22-03-2016, 15:36
wt200999's Avatar
Texas Instruments
AKA: Will Toth
LabVIEW itself has a native Linux version. However teams are not given access to this version. Additionally there are more components that are required for FRC that are not supported by the native Linux version.
Unread 22-03-2016, 15:46
FRC #5090
Ok Thanks.
Unread 24-03-2016, 17:33
It does, yes. But, it's geared towards several very specific builds of Linux. (The page I linked to called this out and pointed out which builds are supported.) With Linux being open source, it's not easy to say "this works on all builds." That's why the ones that are supported are called out individually. Realistically, Linux would have to be supported to some degree as the roboRIO runs Linux and operates with LabVIEW just fine.
Teams aren't given access to the Linux version because it's not helpful to them. Without having the required components supported on Linux, you couldn't use it to program for FRC. It's the same reason there isn't a Mac version for FRC teams.
