Go to Post "In theory it will work" - Fuller [more]
Unread 23-03-2016, 13:09
Paul3161's Avatar
Paul3161 Paul3161 is offline
FRC #3161 (Tronic Titans)
Paul3161 will become famous soon enoughPaul3161 will become famous soon enough
What did you learn from this past build season?
Hey CD,
I was just wondering what was the most important thing you guys learned this past build season. What I learned was that it takes a team to achieve greatness. I thought that I would be able to finish designing the robot all by myself, but shortly after I learned how much this will stress you out. My team did not have enough dedication or experience, and had no idea how to even do the simple stuff.
Now from this I could say that I tried my best, and if I did not help out this season, my team would not have a robot. For next season I will be focusing on training other members to the best of my ability, and working together as a team. If anyone else had this issue, I cannot stress enough how important it is to get others to help out in any way. You cannot do it all by yourself and if you do, you will feel as stressed out as I am now.
Anyways that's what I learned this season! I would love to hear what you guys learned, and how to apply these things to next season.
Paulius Pace
Team 3161 Captain
Unread 23-03-2016, 23:18
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: What did you learn from this past build season?
Last year, we learned what success felt like. (Ranked 42 of 60 at Bayou, got picked by #2 alliance, went to CMP.)
This year, we learned what it takes to earn success - by almost getting there. This year, we ranked #18 of 56, and were the top ranked team not selected for an alliance. It took a bit of cajoling at first, but by the end, we had nearly the whole team down at/near the pit (which happened to be located across a walkway from the pit televisions) waiting on a team breakdown that almost happened about a dozen times.
We also learned a few internal things about mentors staying engaged after students nominally "take over" a function, and a lot of details about how to build and not build a robot. I started a "Lessons-Learned-2016" channel on our slack last night, and it got 60 posts in the first dozen hours.
Unread 23-03-2016, 23:42
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
I think we learned (hopefully)...
Not to get overly complex and IF they listen to me (from a strategy perspective) go after low hanging fruit with the ability to go after high hanging later especially in weeks 1 and 2 competitions.
Have the bot built by WEEK 4..allowing two weeks to drive it and see what breaks and learn what it does best. Iterate 30 lbs at a time thereafter. (At least we were underweight finally)
Do not underestimate STRESSES in a game like this and overbuild strength into every component
If we follow these lessons it should help next year. Another successful year and a very good learning year..we have more work to do. Back to the drawing board...next year
We have one more year with the Freshman becoming Seniors before they are leaving the team...we plan to make it and will do our best. As I say to the team... "Another effective bot" that's our goal every year. First year I can say we delivered on it without reservation. We learn.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 24-03-2016, 00:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Learned how to program, set up, and run a CNC lathe and how to use Autodesk Inventor HSM software. Also, after nearly 15 years, I've learned how to let go, and watch what the students are able to come up with and what they are able to do without me. I've also learned that building a quality pit area takes WAY longer and costs way more than you would ever imagine.
Unread 24-03-2016, 15:10
arc25565 arc25565 is offline
FRC #1482 (Ghosts)
Rookie Year: 2015
arc25565 is an unknown quantity at this point
I learned that when planning things always take longer than you think they will.
I also saw the value in prototyping along with how it is better to have a shooter that is fixed in one place as opposed to variable.
Finally I also learned the importance of team communication and orginization
Unread 24-03-2016, 15:19
Data Nerd
FRC #0079
Pneumatics are wicked.
Also, the New England usage of the word wicked.
Things I didn't learn - How to pronounce the names of anything in New England.
Unread 24-03-2016, 15:32
sawhneyjalaj's Avatar
sawhneyjalaj sawhneyjalaj is offline
AKA: Jell-O
FRC #0384 (Sparky 384)
Team Role: CAD
sawhneyjalaj is an unknown quantity at this point
I've learned that a hammer will fix nearly every problem with mechanical.
Unread 24-03-2016, 17:05
Paul3161's Avatar
Yeah one other thing I learned was when you do something, make sure you do it right the first time. Now this may seem like common sense but some members on my team started a job, and did not finish it properly or left it for someone else to take on. This lead us to having to take apart or robot like 5 times because one thing was not mounted properly.
Paulius Pace
Team 3161 Captain
Unread 24-03-2016, 20:04
mentos54 mentos54 is offline
FRC #0247
mentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to behold
We learned to order parts as quickly as possible, with the quickest delivery time. We also learned to stay updated on the progress of parts being made and shipped, and to plan on them coming in several days late.
Unread 24-03-2016, 20:07
Cam_Team 2619's Avatar
Cam_Team 2619 Cam_Team 2619 is offline
Director/King of The Mill
FRC #2619 (The Charge)
Cam_Team 2619 is an unknown quantity at this point
Restarting 6 days from the end of build season is not easy. Robot in 6 days is not a fun process.
2014 - King of The Mill
2015 - Mechanical Co-Lead/Human Player Backup
2016 - Mechanical Lead
2017 - Director
Unread 24-03-2016, 21:15
lkg9999 lkg9999 is offline
FRC #4761 (Robockets)
lkg9999 is an unknown quantity at this point
Send a message via MSN to lkg9999
Andrew, drop by our pit tomorrow. We'll be happy to coach you in New Englandese: Worcester (WOO-STAH), Gloucester (GLAW-STAH), etc.
Unread 24-03-2016, 22:17
ey206208's Avatar
ey206208 ey206208 is offline
FRC #1701 (RoboCubs)
ey206208 is a jewel in the roughey206208 is a jewel in the roughey206208 is a jewel in the roughey206208 is a jewel in the rough
It worked in CAD.
A long time ago, people who sacrificed their sleep, family, food, laughter, and other joys of life were called saints. Now they are called engineers.
Unread 24-03-2016, 22:32
Data Nerd
FRC #0079
*Sigh* I'll bring my notebook...
Unread 24-03-2016, 22:33
scooty199 scooty199 is offline
FTC and FRC Alum, Robotics Junkie
AKA: Oscar McCullough
FRC #4472 (SuperNOVA)
scooty199 is a splendid one to beholdscooty199 is a splendid one to beholdscooty199 is a splendid one to beholdscooty199 is a splendid one to beholdscooty199 is a splendid one to beholdscooty199 is a splendid one to beholdscooty199 is a splendid one to behold
Maybe there's a reason we're the only robot with tank treads.
Also, you have to build things to be robust in this game.
Oscar McCullough
Booz Allen Hamilton - Software Engineer
Carnegie Mellon University -Mathematics, Computer Science, and Robotics
FRC 2068 - Alumni (2012)
FRC 4472 - Mentor (2013-
VRC 36130 - (2015-
VIQC 36150 - (2015-
VIQC 3615 - (2013-
FRC Team 2068: Metal Jackets Alumnus
2011/12 Chesapeake Regional Finalist Alliance
2011/12 Chesapeake Regional Gracious Professionalism Award
FTC Team 33: Enigma Alumnus
2011/12 VA FTC State Championship - Winning Alliance (Thanks 4105 and 354)
Unread 24-03-2016, 22:59
axiomofdarkness's Avatar
axiomofdarkness axiomofdarkness is offline
FRC #1403 (Cougar Robotics)
axiomofdarkness has a spectacular aura aboutaxiomofdarkness has a spectacular aura aboutaxiomofdarkness has a spectacular aura about
We learned - or at least set a new team record for - how little time the programming team can have with the robot for it to be functional for competition. Apparently it's about 6 hours.
