Go to Post Adversity should be seen as a challenge and not as an obstacle. :D - waialua359 [more]
Unread 13-03-2016, 20:48
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
OpenCV on RoboRIO and Eclipse
Hi there. I'm having trouble making OpenCV work with Eclipse so that we can deploy code to the robot and have our vision system integrated with it. I am following these exact instructions. But when building the c++ project it spits out these errors.
I have tried just opening a USB camera in OpenCV in the program, even if I just #include OpenCV it spits out these errors so it is probably not an issue with the code I have currently.
Unread 13-03-2016, 22:23
joeojazz joeojazz is offline
FRC #5712
joeojazz is an unknown quantity at this point
Re: OpenCV on RoboRIO and Eclipse
Try these instructions it's an old cv (2.4) but same process. http://docs.opencv.org/2.4/doc/tutor...a_eclipse.html
Unread 24-03-2016, 23:36
FleventyFive FleventyFive is offline
FRC #4118
FleventyFive is on a distinguished road
Are you still having this issue?
Try opening WPILIB.h (in your includes somewhere) and commenting out the line "#define REAL". For some reason, having this variable defined messes with opencv
Unread 25-03-2016, 08:25
kylelanman's Avatar
kylelanman kylelanman is online now
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
This thread has a little more information on why this is a safe thing to do. http://www.chiefdelphi.com/forums/sh...8&postcount=18
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
