Go to Post I thought you guys were surposed to be nerds. - Funzo [more]
Unread 24-03-2016, 21:54
Jeringo Jeringo is offline
FRC #4749
Jeringo is an unknown quantity at this point
Can't get data from Network tables
I have recently set up grip on my DS PC and have it post to network tables on roboRIO-4749-FRC.local. I can use outlineviewer.JAR to see the network tables but can't use java to display on the smartdashboard. Could someone give an example from what they have done to get network table values?
Unread 24-03-2016, 22:14
FRC #4749
Re: Can't get data from Network tables
right now i have this
public NetworkTable table = NetworkTable.getTable("Grip/TowerTarget");
Width = table.getNumber("width", 0.0);
SmartDashboard.putNumber("width :", width);
should i use this instead?
Width = table.getNumberArray("width", 0.0);
SmartDashboard.putNumber("width :", width[0]);
Unread 25-03-2016, 10:16
Xanawatt Xanawatt is offline
FRC #1024
Xanawatt is an unknown quantity at this point
You will need to use the second option. You need to put all of the networktables code in teleopperiodic or you will only get one value at the beginning of the code.
