Re: Digital Servo Holding position after disable
Do you have a schematic or a board in front of you to confirm that? |
We had this problem with the servo on our hood until we got a Hitec servo compatible with this guy so we could reprogram it: https://www.servocity.com/html/hpp-2...l#.VvVqMJYrKL8
Anyways, my solution has been to buy another servo. Servocity says futaba digital servos just die when they lose signal. Those weren't available around town, but Savox were. I can personally confirm the Savox die when they lose signal. It looks like just hitec hold position. |
i am spit baling here as this is little out my league but could a simple fix be attaching a spring to the servo to overpower it every-time you cut power to it or turn it off. we did this on our scalier as a break so that if we dont get up high enough when the match ends and they cut the power the spring will take affect turning the servo to place the break mechanism on the scalier.
1) A way to cut the power has not been identified, and 2) When the signal is turned off, the servo tries to hold the last commanded position. Assuming the above is correct, if you add a spring load sufficient to overcome the servo, all you'll do is prevent the servo from moving and possibly burn out the motor. |
#7
