Go to Post It seems ironic to me that a robotics competition would come down to human error, which is precisely what the field of robotics attempts to prevent. - David8696 [more]
Unread 25-03-2016, 23:45
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Re: Digital Servo Holding position after disable
Unless I'm misreading the previous posts, the problem is this:
1) A way to cut the power has not been identified, and
2) When the signal is turned off, the servo tries to hold the last commanded position.
Assuming the above is correct, if you add a spring load sufficient to overcome the servo, all you'll do is prevent the servo from moving and possibly burn out the motor.
that what i thought but it turns out that the servo is strong enough to pull the spring, but without power the spring pulls it back.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
