Re: pic: CGX-108 front
This is a really cool project, and I'm anxious to see the final result commercially available. Although I would be even more excited if you could make your own final stage as well. The Vex final stage has really insufficient mounting strength at high ratios. Two #10 bolts isn't enough to hold the reaction torque (above 100:1 on a bag motor) in our experience.
Nice! Ever since you posted the CAD a few months ago, I was eager to see it come to life.
Good luck on the final iteration! Hopefully this will be something VEXPro will look into in the future, it really is a nice way to get a compact and high reduction stage for Versa Planetaries. |
While I'm still of the opinion that cycloidal gearboxs are magic, the thought of a 20:1 or higher reduction with limited or zero backdrive in a VersaPlanetary form factor is VERY appealing to me. It could also be a way more flexible and compact solution for applications that many teams currently use worm gearboxes for.
We have used the side mounting holes in the past to hold our VPs, so doing that could help. You could also cut 2 more mounting holes such that it holds the VP together; you would use the 2 corner holes that currently house #8 bolts that hold the VP together. Quote:
This is a bit of a resurrection, but has there been any progress on this design? I think this could be a great option for teams wanting to power arms or winches or a host of other subsystems.
#7
Why not just use a stock versaplanetary?
#8
Why not use a single 33:1 stage instead of a 3:1 stage and a 10:1 stage? Also, I'm a fan of non-backdriving gearboxes, and this is a much more robust option over the window motors.
#9
Easy enough for me. |
#10
Every new design has to start somewhere. When Versaplanetaries first came out they didn't have nearly the testing hours they do now.
#11
They may not have had the amount of testing they do now. But I'm certain that a company as large as vex would have done some pretty in depth testing before putting it in the hands of first teams. That being said I do agree that this would still be a cool thing to see produced and used on an frc bot.
#12
![]() Single stage cycloid backdriving! Last edited by ajlapp : 17-10-2016 at 20:33. Reason: Added video link |
