Go to Post ... Better to treat everything like it's about to explode and be wrong than the other way round. - Bongle [more]
Unread 27-03-2016, 17:58
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: COMM lost way to many times
Weidmuller connector length
Strip the wires that are inserted into the various Weidmuller connectors to the required length. Often teams make these too short and the result is the wire is not properly retained.
What is the required length?
The PDP, PCM, and VRM documents list 3/8". The FIRST video on using Weidmuller connectors says 5/8"
I believe the spec is actually 8mm but I just want to make sure since the official FIRST video says something different.
Radio PoE
Also has anyone found a COTS solution to doing PoE for the radio? The adafruit set didn't work in my testing.
Unread 28-03-2016, 00:09
How were you trying to use it? From what I can tell, each of the two parts in that pair is wired properly to work with the 18-24v POE port on the radio, as long as you get the polarity correct on the power wires. The only difference is what type of barrel connector it has, and you'd be cutting that off anyway in order to connect to the VRM.
Unread 28-03-2016, 02:27
Engineering Coach
Wow that would probably be my problem I just did a quick test using the barrel we already had connected, didn't realize the power and ground were reversed. I'll cut it tomorrow and make sure it works.
Unread 28-03-2016, 10:15
The page that video is embedded on contains this note:
The correct strip length is ~5/16" (8mm), not the 5/8" mentioned in the video.
Unread 28-03-2016, 12:48
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
From the VRM users guide
Strip wire back ~0.375” (3/8”)
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
