Go to Post Minus the one time when our Autonomous mode actually reversed, ran into the robot behind us, and lodged them into the rear wall - MysterE [more]
Unread 27-03-2016, 21:47
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Issues with JNI .so for FRC
We are attempting to build a JNI shared library for use in our java code. We are using ant to build the library as follows:
  <target name="CowMXP_JNI-build">
      <echo>Building CowGyroJNI shared object for RoboRIO...</echo>
      <apply executable="/usr/local/bin/arm-frc-linux-gnueabi-g++">
      <arg value="-I${user.home}/wpilib/cpp/current/include"/>
          <arg value="-I${java.home}/../include"/>
          <arg value="-I${java.home}/../include/darwin"/>
          <arg value="-std=c++14"/>
          <arg value="-fPIC"/>
          <arg value="-shared"/>
          <arg value="-oCowMXP_JNI.so"/>
          <arg value="-Wl,--whole-archive"/>
          <arg value="-L${user.home}/wpilib/cpp/current/lib"/>
          <arg value="-lwpilib_nonshared"/>
          <arg value="-lntcore"/>
          <arg value="-lHALAthena"/>
          <arg value="-Wl,--no-whole-archive"/>
          <fileset dir="src/com/team1538/lib/c">
            <include name="*.cpp"/>
        </fileset>
      </apply>
  </target>
and running into an error resolving _ZN5nFPGA16nFRC_2016_16_1_020g_currentTargetClassE . Does anyone know what static library provides this? We are already using all static libraries available in wpilib/cpp/current/lib.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 27-03-2016, 23:24
Re: Issues with JNI .so for FRC
austin[23463] iron ~/local/robotics/971-Robot-Code/bazel-971-Robot-Code/external/allwpilib_ni_libraries_repo
$ grep -R "_ZN5nFPGA16nFRC_2016_16_1_020g_currentTargetClassE" ./
Binary file ./libFRC_NetworkCommunicationLV.so.16.0.0 matches
Binary file ./libRoboRIO_FRC_ChipObject.so.16.0.0 matches
austin[23464] iron ~/local/robotics/971-Robot-Code/bazel-971-Robot-Code/external/allwpilib_ni_libraries_repo
$ c++filt
nFPGA::nFRC_2016_16_1_0::g_currentTargetClass
austin[23461] iron (master) ~/local/robotics/971-Robot-Code
$ git grep g_currentTargetClass
third_party/allwpilib_2016/hal/lib/Athena/FRC_FPGA_ChipObject/nInvariantFPGANamespace/nInterfaceGlobals.h:   extern unsigned int g_currentTargetClass;
third_party/allwpilib_2016/hal/lib/Athena/FRC_FPGA_ChipObject/nRoboRIO_FPGANamespace/nInterfaceGlobals.h:   extern unsigned int g_currentTargetClass;
third_party/allwpilib_2016/hal/lib/Athena/FRC_FPGA_ChipObject/nRuntimeFPGANamespace/nInterfaceGlobals.h:   extern unsigned int g_currentTargetClass;
Looks like part of libRoboRIO_FRC_ChipObject.so
Unread 28-03-2016, 00:54
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Note that libRoboRIO_FRC_ChipObject requires other libraries, so you'll probably need to link to nearly every .so in cpp/current/lib. There's two ways to do this: the standard JNI .so (which is built using gradle) explicitly links every .so except libwpi.so and libwpi_2015.so. When building C++ via eclipse, libwpi.so is referenced, which is actually a text file which references libwpi_2015.so, which is also a text file which references a bunch of .so's as well as a couple of .a's.
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 28-03-2016, 01:03
Got it - we later found that libHALAthena.so was missing from the roboRIO and copied over all libs to /usr/lib. Finally worked.
Team 973 (2016-???)
日本語でOK
Unread 28-03-2016, 08:22
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
All of of those libraries (with the exception of libHALAthena.so) were taken directly from the roboRIO to start with. They're in a few ni locations, a find on /usr should show them.
Unread 28-03-2016, 20:43
New issue - when the JNI library is loaded, our Talons refuse to enable in auto / teleop. Any insight into this?
Team 973 (2016-???)
日本語でOK
Unread 28-03-2016, 20:53
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Do they enable but not get commands (solid yellow), or stay disabled (blinking yellow) when you switch to auto and teleop?
One thing I do wonder about is if you are using the default WPILib in addition to the custom built JNI. The default WPILib has the JNI library built into the JAR, and I wonder if the built in one is conflicting with the custom one you built. Are you modifying WPILib completely, or just trying to add something on top?
Team 4488 - Mentor 2013-2016
Unread 28-03-2016, 20:56
They're blinking yellow/orange (pardon my colorblindness). We're wrapping some 3rd party MXP code in JNI rather than porting it. I also suspect a conflict, but I'm not sure where it would arise.
Team 973 (2016-???)
日本語でOK
Unread 28-03-2016, 21:26
Nevermind - found the bug in our JNI code! Had multiple calls to HALInitialize. I'll post notes on the stuff we did when I have some free time.
Team 973 (2016-???)
日本語でOK
