Re: Stumped on camera feed not available at driver station but only in matches
Camera has a fixed IP of 10.TE.AM.11
Now that you mention it, .11 is the right number.
Is the Subnet mask of the camera and driver station set to 255.0.0.0? I just saw that you could open a web page to the camera, but not a Smart Dashboard image. We had that same problem 2 years ago, and just used the web page image. I'll have to ask our programmers how they fixed the problem this year. I think it had to do with getting the Smart Dashboard parameters right. Did you give Smart Dashboard the fixed IP address, and not let it look for the mDns address? Last edited by rich2202 : 28-03-2016 at 01:14. |
the driver station has a fixed ip also. we can connect to the camera web page but the live image doesnt show on the screen. just an empty box. some matches it does work however.
How is the camera addressed in the dashboard code? Is it assigned the fixed IP address or is it assigned by the network name?
In the 2015 season, we found we had to restart the dashboard before we went to the field or our USB camera would not show. The source of this issue was the dashboard grabbing using the IP address it picked up in the pits (172.22.11.2 or other) and not using DHCP to grab the new IP address on the field (10.X.X.X). You may be having a similar issue. |
My suspicion is that the code is trying to establish a connection, but the other side isn't ready, so it gives up or doesn't successfully continue trying to establish in the background.
The LV dashboard has a dedicated loop that twice a second checks the connection. If it isn't valid or has an error, it closes anything it has and reopens the session. If the web browser works with the camera, and the SD client doesn't, the issue is with the client. You may also want to try the default dashboard in its IP mode. Bayou had a team that started with the default DB, established the connection, then closed and opened the SD. That was their self-discovered process for getting it to work on the field. Greg McKaskle |
#7
I'm not much of a coder, so i don't know half of what the suggested fixes are, but during my team's regionals, the cameras would work when tethered at the pit, but would mysteriously not show up with FMS connected. For whatever reason "RIOsetting" (resetting the rio) just after setting up on the field fixed our problems.
TLDR: RIOset the bot prior to retreating to driver station |
#8
We isolated the issue to the specific lap top we were using for driver station and vison processing. There was an issue with the network chip/driver that we could recreate high occurance of dropped packets but in the end couldnt determine the specific issue. Changing to a duplicate laptop resolved the problem.
#9
I'm guessing it is a setting on the camera. Or, an antivirus or other similar program interfering. Also, there are specific UDP(?) sockets that the camera is supposed to be using. Make sure it is one of those. If it worked through FMS without any other teams on the field, this may not be the problem, but you might want to check anyway. FMS should block wrong usage regardless, but maybe not. Last edited by rich2202 : 28-03-2016 at 07:15. |
#10
I have a vague memory from a couple of years ago about Axis cameras and the Java Smart Dashboard. Might you need to enable anonymous access in the camera's web configuration?
