Go to Post I believe the only cure... is more cowbell? :D - The Megan 2207 [more]
Unread 28-03-2016, 07:30
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: "Robot Code" won't turn green, but no errors are displayed
Never had that happen before, but this is what I would do:
1) Connect directly to the RoboRio's ethernet port, and try again.
2) If you connect to the RoboRio's USB port, are there any logs you can look at?
3) Load some basic robot test code - print "hello world" to make sure the process works.
4) Re-image the RoboRio. Seems like a fundamental problem.
5) Load some basic robot test code - print "hello world" to make sure the process works.
6) Deploy the new code.
