Go to Post Very few things are impossible. A great many things are impractical, but not impossible. - Wetzel [more]
Unread 28-03-2016, 09:20
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Flow Valves
Originally Posted by s5511 View Post
Also, would having two pistons run off the same solenoid produce less upwards force on the mechanism than having the two pistons run off of different solenoids?
As GeeTwo stated the force is the same, but you may have some unexpected motion. If you have the cylinders moving independent mechanisms, you may see that one mechanism moves first, then the second mechanism will move.
Depends on static friction, hose distance from each cylinder to valve, mechanical differences.
There are times when it pays to save the money on the second valve, and times when it pays to have the second valve. Depends on quickness, and control needed.
The sooner we get behind schedule, the more time we have to catch up.
Unread 28-03-2016, 09:36
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Re: Flow Valves
... and you can get both of these for free at AutomationDirect using the voucher in the KOP ...
Go to AutomationDirect.com and search on "Flow Control?" There are about 100 options ...
Unread 28-03-2016, 10:07
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Re: Flow Valves
If the hoses are cut to the same exact lengths, the two cylinders' motion should be in sync.
Unread 28-03-2016, 10:30
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Re: Flow Valves
Hose length is only one of the variables. Load, Static Friction, Internal friction of the cylinders, flow control settings for each cylinder, mechanical mounting of each cylinder (variance give one cylinder a mechanical advantage than the other), fittings used on both sides, etc.
Once one cylinder over comes static friction, it will finish it's stroke first. With flow controls you can typically force the cylinders to break away relatively balanced in a FRC application, but at the expense of speed.
http://hydraulicspneumatics.com/othe...inder-movement
Much of the info on the page they talk about hydraulic and pneumatic in the same instance, but the with the compressablility of air, syncing pneumatic circuits are much harder than hydraulic.
The simplest circuit uses only flow controls to build resistance to hold the fast cylinder back. The accuracy of flow-control synchronizing is only fair to poor.
