Go to Post I think the GDC just saw Inception. - rtfgnow [more]
Unread 20-03-2016, 19:26
D.gimon D.gimon is offline
FRC #5324
D.gimon is an unknown quantity at this point
Help Needed!!! No Robot Comm, No Code.
Hi,
Tried setting up a new laptop to use for the Driver Station.
Installed all software as per SSLive instructions.
Deploy code and build is successful.
Open Driver Station, No Comm, No Code.
However, Driver Station icon has a blue and yellow shield superimposed on it in bottom right hand corner which I haven't seen before.
I check through "Web based Configuration" and all is good.
Please Help!
Unread 20-03-2016, 19:53
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Help Needed!!! No Robot Comm, No Code.
Originally Posted by D.gimon View Post
Hi,
Please Help!
Make sure that windows firewall and defender along with any other such softwares (mcafee, norton, etc.) are disabled.
Unread 20-03-2016, 20:37
FRC #5324
It's a school board laptop that runs ESET Antivirus. could that be the problem? I can't turn it off.
Dan
Unread 20-03-2016, 20:39
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
We had to have our school IT guy disable the Symantec suite on our backup notebook before we could use it for much of anything. This is probably your problem.
Unread 20-03-2016, 20:43
AKA: Alex Tannahill
Dan
Can you whitelist certain programs or ports? The ports that are used are listed in the manual.
Unread 21-03-2016, 08:38
I think that's Windows telling you that the Driver Station program will need to be run with elevated privileges in order to function properly. Try running it as Administrator and see if the communication works.
The best option is probably to log on with an administrator account instead of a limited user, turn off the antivirus and firewall, and then be very careful about what you click on if you ever connect it to the Internet.
Unread 28-03-2016, 11:21
FRC #5324
Thanks Alan. I suspected that. Thanks for confirming it. We managed to get the old laptop operational and will try the new one again once our school board IT guy gets back from vacation.
BTW all original issues were being caused by bad programming. Don't really understand why the code would compile and load without any faults though.
Dan
Unread 28-03-2016, 11:59
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
The locked down domain-joined school issued laptops are a pain at competition. I highly recommend using a laptop dedicated just to being the driver station, with a fully updated fresh Windows 10 install with no crapware and third party antivirus/antimalware software. The only software installed on the laptop should be the driver station software, and it should not be used for anything besides driving.
There are lots of options for durable, cheap, used laptops under $100 that make excellent driver stations.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
