Go to Post Learn to respect the opinions of others, even if they are the complete opposite of yours. - Hallry [more]
  #76   Spotlight this post!
Unread 28-03-2016, 09:46
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: COMM lost way to many times
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
  #77   Spotlight this post!
Unread 28-03-2016, 09:48
Bruceb's Avatar
hope this works
  #78   Spotlight this post!
Unread 28-03-2016, 10:15
Originally Posted by AllenGregoryIV View Post
The FIRST video on using Weidmuller connectors says 5/8"
The page that video is embedded on contains this note:
The correct strip length is ~5/16" (8mm), not the 5/8" mentioned in the video.
  #79   Spotlight this post!
Unread 28-03-2016, 12:48
Bruceb's Avatar
From the VRM users guide
Strip wire back ~0.375” (3/8”)
  #80   Spotlight this post!
Unread 28-03-2016, 12:59
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Originally Posted by Bruceb View Post
we had several folks look at the fuses and they were deemed OK but I will pull them and insert new ones Thursday.
Thanks
Make sure you smash them in there. Excessive force is necessary for them. Also, make sure the power connections to and from the VRM are done properly. When they're secured the right way, you should be able to pull on them with all of your weight without them moving.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
  #81   Spotlight this post!
Unread 28-03-2016, 13:16
Zagar's Avatar
Zagar Zagar is offline
Electrical Mentor 1506 Metal Muscle
AKA: "Always waiting for Electrical..."
FRC #1506 (Metal Muscle)
Team Role: Electrical
Rookie Year: 2015
Zagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of light
Ok, not on topic, but I have to ask what kind of tires are those?
And on topic, we too lost comms on our first match this past weekend. We were told that we should not have tinned the wiring going into the VRM....
  #82   Spotlight this post!
Unread 28-03-2016, 14:00
Bruce,
I know that this doesn't help you at this point but there doesn't seem to be any strain relief on the power plug for the radio. The barrel connector depends on the "spring force" of the outside contact to hold everything in place. I highly recommend using an adhesive backed wire tie point on the top of the radio. Loop the power wire up to the tie point and then secure with a a small wire tie. This small step keeps the connector from bouncing around and prevents pullout. Tape over the connector to the radio body also works. The antennas for this radio are on the sides of the radio, inside the vents. It doesn't help to have the stainless pneumatic tanks on that side of the radio but shouldn't be a big problem.
There is also the possibility that severe vibration has caused the power plug to pull out of the circuit board. This is easily repaired if the circuit board has not been damaged. The connector is a part of the circuit board that a good hit on the connector could cause a crack in the board. This has the same effect as broken wires. It may work most of the time, but vibration will make it lose the power.
Tinning wires is not recommended for Weidmuller terminals. They depend on the deformation of the strands to give maximum surface area for current to flow. With tinned wire, only the extreme outside surface of the wire touches the contact producing a connection equivalent to a #36 or smaller wire.
  #83   Spotlight this post!
Unread 28-03-2016, 14:11
Team34Guy's Avatar
Team34Guy Team34Guy is offline
Controls/Programming Mentor
AKA: Chris Southard
FRC #0034 (Rockets Team 34)
Team34Guy is a jewel in the roughTeam34Guy is a jewel in the roughTeam34Guy is a jewel in the rough
We experienced the same thing at both the Arkansas and Rocket City Regionals. After speaking to other teams at Rocket City, the consensus was the power connection at the radio. It isn't as reliable as the D-Link. I found ours had backed out a little over an 1/8" and most likely lost connection briefly when we struck the wall in autonomous. Bomb Squad mentioned that they had experienced some issues prior to competition and had hot glued their connector, they didn't have any further issues with that connection.
It's extremely frustrating to say the least....Especially when Bob starts fussing! (cause usually he's right)
  #84   Spotlight this post!
Unread 28-03-2016, 14:18
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
One of the other things that hasn't been metioned is the use of ferrules with the weildmuller connectors. We used them on nearly all of our competition robot connections and have had zero issues.
Here is the white paper from Weildmuller recommending their use with stranded wires.
We import ours from China using Aliexpress but you can also get them from US electronics vendors, ebay, or Amazon.
Make sure you are using the right crimp tool and gauge ferrules. Also get 8mm long ones.
  #85   Spotlight this post!
Unread 28-03-2016, 14:37
Engineering Coach
This thread inspired me to write up this document. Anyone have any more suggestions to include.
https://docs.google.com/document/d/1...XrCy1gzk/edit#
  #86   Spotlight this post!
Unread 28-03-2016, 16:54
Bruceb's Avatar
they are 9.4 inch beach tires. 3 psi and they litterally float over the defenses
  #87   Spotlight this post!
Unread 28-03-2016, 17:02
Bruceb's Avatar
Bruce,
Al that was an old pic just to show the location of the radio. At the time of our latest comm losses during elims we had a new tighter barrel jack taped in place AND we were running POE. so we had two power sources.
this bot had been gone over by nearly every orange and yellow hat at both Cleveland and Milwaukee. After replacing the barrel jack and installing POE in Milwaukee we had no issues until the last match of quals then it started all over again. Had Pete Thomas doing everything he could think of during elims but he found nothing.
is it just the 706 curse? 6 time finalist in the last 4 years.
Thanks
  #88   Spotlight this post!
Unread 28-03-2016, 17:05
Bruceb's Avatar
one other thing
we NEVER lost comms during extreme contact with another robot or flying over defenses. It always happened when just starting to cross the defense and even happened when crossing the low bar once.
I am beginning to think a static discharge may be part of the problem as we noticed a static discharge when crossing defenses on the practice field.
  #89   Spotlight this post!
Unread 28-03-2016, 17:38
Engineering Coach
From looking at logs and reported observations from the FTA's they see the radio rebooting. Immediately after they see the radio return they see the RIO so the belief is that the RADIO is the only think rebooting as the RIO takes longer than the radio and would not show up immediately after the radio if it was also booting.
Do you have the driver station logs from those matches that you can post?
There is also a system log file you can pull up using the RoboRIO webpage as well. We had a problem at Bayou were we were seeing the RoboRIO just crash for no reason (not our code but the whole RoboRIO, as in it stopped even showing up as a USB network adapter to computers once that crash happened, we never found the problem and just swapped RoboRIOs)
  #90   Spotlight this post!
Unread 31-03-2016, 08:59
Bruceb's Avatar
I will see if I can have our programmers post those from finals matches.
