Re: Kudos for Alamo Regional format.
mediocre movie tbh
Yikes!!
This is Ryan's (and others) position on referee replay's. This feed gave mutlti angle shots of the field so questions can be asked against the replay. Please post what you used to make this feed, and can you include the count of the hundreds of people required and the thousands of dollars spent? |
The feed was handled by Solomon group to my knowledge. The same people that do most of the AV for FIRST regionals (at least all the ones I attend). I'm enjoyed their feed as well and I'm looking to figure out how to pull it off with less professional equipment.
In Georgia they use multiple cameras, where they switch between views during the match. I have no idea how hard or how expensive it is to merge in to a hybrid feed.
Thank you to BradB from 4063 & Manning Robotics for cutting & uploading Alamo videos !
http://www.thebluealliance.com/event/2016txsa Anyone want to help cut more videos ? All the matches are up on the full stream. |
It does not cost anything to put it into a hybrid feed. It is just a matter of having enough cameras + capture devices. With something like a Blackmagic switch (around $1,500) you would have enough inputs to run this sort of thing. From there you can output it into your favorite streaming software (Xsplit, OBS, ect) and lay everything out how you like.
Many events already have camera switches just most of the time they use a single output to the livestream. |
#7
I agree. I really like this format. Several years back, we were experimenting with some layouts, and this is great.
