Go to Post Isn't that the name of the game... Roomba Rumble? - Mr. Van [more]
Unread 29-03-2016, 13:21
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Re: T-Shirt Cannon
My students discovered that a shirt folded to be tight in the barrel shoots much farther than a loose one - although the tight shirt has more friction on the way out, it seals in the barrel much better.
Plastic tanks and barrels have always made me nervous (and I'm not an ME, and I'm sure this has been discussed elsewhere.) An industrial arts teacher at a school 668 is helping suggested copper. It's readily available, and tears rather than breaks up into shrapnel. Yes, it's also more expensive, but it takes a good shine! And it's a good way to prepare future homeowners to solder their water lines.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 29-03-2016, 15:15
snotsdelta snotsdelta is offline
FRC #6056
snotsdelta is an unknown quantity at this point
Re: T-Shirt Cannon
Originally Posted by cbale2000 View Post
This. Keep in mind that smaller tubing will restrict flow, so while your air compressor can be connected using standard 1/8" tubing, everything between the tank and the cannon should be 1". Consequently, you're probably not going to want to use a standard air tank like you might find on AndyMark, look for one with 1" ports (or 1/2" ports and use several of them to merge to a 1", since 1" port air tanks are really hard to find).
This is great info. Thank you! Do you know of any websites that would be good to order from for the tank?
Unread 29-03-2016, 23:10
plurp911 plurp911 is offline
FRC #3501 (Firebots)
plurp911 is an unknown quantity at this point
Re: T-Shirt Cannon
I would suggest just checking out this link if you want to make a relatively cheap T-shirt cannon (mostly out of PVC):
http://www.instructables.com/id/T-shirt-Cannon/?ALLSTEPS
Unread 30-03-2016, 08:51
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: T-Shirt Cannon
Ummm, yeah. Do Not do this with PVC. Please.
___________________
- Tennyson, Ulysses
Unread 30-03-2016, 09:50
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
Re: T-Shirt Cannon
I will second this. Flying plastic = very dangerous projectiles in a crowd.
[=Daniel_LaFleur;1565142]Ummm, yeah. Do Not do this with PVC. Please.[/quote]
Team member 2004-2008
Team mentor 2008-20XX
http://team1708.steelcityrobotics.or...tics/Home.html
"Education is a powerful tool. Always use it to better someone else's life"
Unread 30-03-2016, 21:48
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: T-Shirt Cannon
Tanks of this type are fairly easy to find on automotive supply websites or Amazon (they're typically used for air horns and other such things). I found this site with a quick search but you'll probably want to search around a bit to see if you can find a tank with the large ports but without a huge capacity (it has to be small enough to be portable after all).
On the note of using PVC, generally speaking I agree that PVC should be avoided, especially for the accumulator (air storage), but to be honest there is far less pressure involved for a much shorter amount of time when using PVC for the barrel of a cannon. IMO if you're really that concerned about it, and can't get a suitable pressure-rated metal tube, build a small polycarbonate (or whatever) box around the bottom half of the barrel to catch shrapnel in the event of a failure. Lots of teams have built PVC t-shirt cannons and no one has died yet (that we know of).
Unread 30-03-2016, 22:04
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Here is a site that has aluminum tanks, and high flow electric solenoids. http://www.hopposonline.com/3-gal-tank/
Unread 08-04-2016, 14:56
FRC #6056
Re: T-Shirt Cannon
Originally Posted by SamM View Post
We use one of these valves on our cannon:
http://www.electricsolenoidvalves.co...olenoid-valve/
A little bit more expensive than the sprinkler valves, but it's rated for air pressure.
When we wired it to our PCM we keep getting a solenoid fault on it. We changed our program to a single solenoid as we were using a double. Just wondering if we had to do something different wiring wise as there is no errors in our program
Thanks!
Unread 08-04-2016, 15:07
SamM SamM is offline
FRC #5842 (Royal Robotics)
SamM is just really niceSamM is just really niceSamM is just really niceSamM is just really niceSamM is just really nice
Re: T-Shirt Cannon
The PCM may not be able to supply enough current for the larger solenoid. You may need to use a victor or another speed controller to supply power to it, which is what we did. You could also probably use a small automotive relay.
"The universe is probably littered with the one-planet graves of cultures which made the sensible economic decision that there's no good reason to go into space--each discovered, studied, and remembered by the ones who made the irrational decision." -Randall Munroe, XKCD
Unread 08-04-2016, 15:20
FRC #6056
Re: T-Shirt Cannon
Great Thank you! So then we will wire the solenoid though the Victor to the PDP then correct? Thanks again!
Unread 08-04-2016, 15:33
Re: T-Shirt Cannon
Yes, just treat it as a motor and run it at full power when you want it to open and no power when you want it closed.
Unread 08-04-2016, 19:50
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: T-Shirt Cannon
We switch the solenoid valves on our air cannon with a 12 relay module similar to this one. Our first iteration used a spike relay, with one valve powered by M+ and the other by M-, with a common 0V (ground) return.
Unread 09-04-2016, 10:09
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: T-Shirt Cannon
*gets up on soapbox*
1> The pressure in the barrel is enough to fire the t-shirt, thus it is enough to fire PVC shards.
2> A box around the lower half of a PVC cannon might help. Are you willing to risk your students (or worse the public) should you be wrong?
3> As to your last line -- does someone need to die to get people to stop using PVC in gas pressure applications?
As an engineer, you need to always understand how safe your product is. T-shirt cannons, by their very nature, will be used near the public. If the t-shirt can reach the crowd, so can shards from a sundered barrel.
JM(NS)HO
*gets off soapbox*
___________________
- Tennyson, Ulysses
