Go to Post This thread is a reminder to myself that I have 29 more days to sleep. :) - Seth Mallory [more]
Unread 29-03-2016, 15:15
snotsdelta snotsdelta is offline
FRC #6056
snotsdelta is an unknown quantity at this point
Re: T-Shirt Cannon
Originally Posted by cbale2000 View Post
This. Keep in mind that smaller tubing will restrict flow, so while your air compressor can be connected using standard 1/8" tubing, everything between the tank and the cannon should be 1". Consequently, you're probably not going to want to use a standard air tank like you might find on AndyMark, look for one with 1" ports (or 1/2" ports and use several of them to merge to a 1", since 1" port air tanks are really hard to find).
This is great info. Thank you! Do you know of any websites that would be good to order from for the tank?
