Re: Antenna design
I suggested we get a bunch of fans and hook it up to a speed controller and get a inflatable tube man. Unfortunately my idea was shot down
https://youtu.be/cvaRGiMWRaE |
Re: Antenna design
We used Orange Fiberglas arrows ($3.00 each at Dick's Sporting Goods) with two different color fletchings. We cut the points off and epoxied to door stop springs ($1.50 for two at Lowe's). They work great!!
Re: Antenna design
If you were to grab one and forcibly twist it while pulling sideways, you might be able to get it outside of 15", but they don't interact with the defenses that way, nor do they have enough weight to do so on their own. Last edited by Steven Smith : 29-03-2016 at 22:34. |
Re: Antenna design
2363's flag solution really suffered when it got battered by the low bar. At our most recent event (VAPOR), about 14% of all our recorded pit activity went towards flag maintenance/repair, mostly in <5 person*minute chunks. Our drivers really liked having them though. |
Re: Antenna design
Re: Antenna design
We have had a lot of requests on our flag design. We call them our "ding-a-lings"
We definitely got a kick out of it when the game announcer started calling them by their names as well. Overall they are pretty simple. We bought ATV flags from this site: http://aditudegear.com/flags We also bought a spring mount like this: http://www.amazon.com/Wheeler-Whip-S.../dp/B005HJL94A The spring mount was far too rigid so we went to Lowes and bought another spring and custom turned a plug to press fit it in the spring that was better suited for us. It is the same exact concept as the one I referenced above. We then mounted this spring base to an angle bracket on the side of our poly-carbonate shields. You can kind of see the mounting application on the picture that the OP provided. They work great for us and we love the visibility that they provide. They also help us square up on the defenses better because we can see them over the tall defenses. Hopefully this helps! |
#7
Re: Antenna design
