Go to Post A dedicated team is a happy team. - sgreco [more]
Unread 29-03-2016, 15:10
quillford quillford is offline
FRC #5924
Rookie Year: 2015
quillford is an unknown quantity at this point
Boulder inconsistency issue
Throughout most of build season we tested with only one boulder and tuned everything based off that one boulder, but as soon as we got a new one we noticed that it shot completely differently. We resolved to simply be a low goal shooter for our first regional, but now I want to look at the high goal again. I was thinking of increasing the compression (we're at 1.5" IIRC), but we were using bags for most of our testing and more compression would stall the motors on intake. Since switching to 775pros, we have not tried more compression. Does anyone have any other suggestions?
Unread 29-03-2016, 15:12
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Boulder inconsistency issue
Gearbox? I think we're running 30:1s (don't quote me on that) on single bag motors with a ton of compression and we have no pickup issues at all
Unread 29-03-2016, 15:18
FRC #5924
Rookie Year: 2015
We're running them with versaplanetaries 1:1 just for the ease of mounting. Are you shooting in the high goal with that much reduction?
Unread 29-03-2016, 15:34
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Just for reference, two 775Pros at 3:1 reduction is more than enough to make high goal shots. Tuning your compression, ball feeding, and geometry is often the harder problem. A lot of teams are doing well with 3 inches of compression.
Unread 29-03-2016, 16:16
FRC #5924
Rookie Year: 2015
I don't think we have any 3:1 stages. Would a 775pro with a CIM-ile on each side work?
Unread 29-03-2016, 16:23
Data Nerd
FRC #0079
Try it. Welcome to prototyping.
Unread 29-03-2016, 16:44
george.tan's Avatar
george.tan george.tan is offline
Raider Power!
AKA: George
FRC #3005 (RoboChargers)
george.tan is on a distinguished road
We had some luck using mini CIMs. I think you'll have the ball inconsistence issue regard less of which motor you're using. I know a used ball have a different trajectory compare to a brand new ball. I think you really need to take some time to find the sweet spot for your shooter. Don't go for the long shot. Dial in your shot at the base of the castle, that should give you a few more points per cycle. Good luck prototyping and enjoy the process.
Unread 29-03-2016, 17:02
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Welcome to the lessons of Rebound Rumble. After playing with the scoring pieces for a few minutes, we ruled wheeled shooters out. The balls were just too wonky. It really doesn't matter what motors you use. The inconsistencies will persist.
Unread 29-03-2016, 19:18
Deke's Avatar
Deke Deke is offline
no team (No Team)
Deke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the roughDeke is a jewel in the rough
There are ways to shoot the ball where the inconsistencies from ball to ball don't affect the trajectory. Keep playing with grip, speed, ball centering, and compression and I'm sure you'll find success with a wheeled shooter.
Unread 29-03-2016, 19:23
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Reduction and gearbox choice offers no help when talking about this unless you include wheels sizes as well.
How am I going to know if you use 20" wheels for 2" wheels.
The only information I have is RPM
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 29-03-2016, 19:28
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Just as another approach (instead of the mechanical side), here's a programming side:
Tune a PID control with a feedforward on the shooter motors. For us, this significantly decreased ball consistency problems with high shots. Although the ball is shot out really fast, there is enough time to somewhat correct the RPM back to your set RPM as the shooter is slowed by the ball going through it.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 29-03-2016, 20:01
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Thats what 4592 is running. we found 2 inches of compression was enough to shoot high goals from the low bar although I would not be surprised if 3-4 inches of compression would be more ideal. We currently run 3 4x7/8 colson wheels per side at 3370 RPM for most ranges. Also, the mechanism pushing the ball into the shooter wheels had a large effect on accuracy. Switching from pushing the ball by hand to a pneumatic indexer altered our RPM by about 200 to get the same shot.
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 29-03-2016, 21:42
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
there's still time to join #TeamPneumatapult
Unread 29-03-2016, 21:47
wilsonmw04's Avatar
Coach
#TeamPneumatapult for life.
Unread 29-03-2016, 22:41
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
#SpringPunchers for the win!
It isn't shiny enough.
