Go to Post In my opinion, leaders do not need to be picked. They naturally emerge as time goes on and as more opportunities are presented to them. - Alex Golec [more]
Unread 29-03-2016, 23:47
josephno1's Avatar
josephno1 josephno1 is offline
FRC #3647
Rookie Year: 2015
josephno1 is an unknown quantity at this point
Re: "Robot Code" won't turn green, but no errors are displayed
I had the same issue during the San Diego Competition.
Make sure all sensors that you are calling actually exist, it took me a while but I found that I was calling for a Sonic Sensor on Analog port 1 when it was on port 0.
I would just make a very simple program and seeing if that uploads
package org.usfirst.frc.team3647.robot;
import edu.wpi.first.wpilibj.BuiltInAccelerometer;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
	private BuiltInAccelerometer accel = new BuiltInAccelerometer();
	public void robotInit() {
	 * This function is called periodically during autonomous
	 public void autonomousInit(){
	public void autonomousPeriodic() {
	 * This function is called periodically during operator control
	public void teleopPeriodic() {
		SmartDashboard.putData("Test", accel);
	 * This function is called periodically during test mode
	public void testPeriodic() {
Go Team 3647 Millennium Falcons!
